turbo coolant lines
matt j
turbo coolant lines
Post by matt j »
Ok i didnt know which section to put this in but i hope this is right. I have a ej22t in my 98 impreza, i am not running a water box and im trying to hook up my coolant lines for the turbo. I have the factory port off the head as the feed, but where can i return it to? Please let me know asap thanks!
Re: turbo coolant lines
the coolant line returns back into the head.
wtdash
Post by wtdash »
Hi,
EDIT: Found this post showing the coolant flow diagram HERE.
And for reference here's the NON-turbo / NA EJ22e version:
The Turbo's water pump has an extra port connected to the coolant tank for the '92-'94. The '91 turbo water pump also has one that connects to the oil cooler.
I've read over on RS25.com (more info there than here for Impreza swaps) that people either tap into the throttle body/IAC coolant lines or the heater core lines.
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
I would suggest dumping the turbo coolant return into the heater core return line. Make sure you tap the correct line or the coolant won't flow correctly.
Tapping into the TB/IAC lines won't provide enough flow.
wtdash
Post by wtdash »
Legacy777 wrote:I would suggest dumping the turbo coolant return into the heater core return line. Make sure you tap the correct line or the coolant won't flow correctly.
Thanks. I was wondering if the TB/IAC was sufficient. I'll also use the HC lines.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
matt j
Post by matt j »
i was thinking the heater core line was going to be the one just was hoping not. I tapped into the iac and tb and it didnt work at all. so which hose is usually the return line? lol
wtdash
Post by wtdash »
Scroll thru this POST on RS25.com. I 'think' the stock hoses have arrows pointing you in the right direction. Follow the hard lines on the engine to help, too.
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
The hose coming from the heater core that connects to a hard pipe that goes under the driver's side head and to the water pump is the return line.
