fuel injectors size
fuel injectors size
What fuel injector size should I get after doing a td 04. Mine gave out.
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
Re: fuel injectors size
You can use stock injectors just fine. 440+ will require a RobTune or PP6. Stock ECU can technically run 440s but it will run terrible.
Yeah, you can run a TD04 at 12psi on stock injectors. Maybe a few hairs higher but with stock fuel cut your shooting yourself in the foot past that.
I have an FCD, TD04 at 15psi.
Run the stock injectors with the stock ECU, no exceptions unless you have some other form of engine management.
