ej20 with ej22t heads
Posted: Sun Jun 21, 2015 7:45 am
by bcmaxx
Well my spare ej22 is scrap.....i have a ej20 wrx usdm block. Will it work with my ej22t heads?
Re: ej20 with ej22t heads
Posted: Sun Jun 21, 2015 1:37 pm
by cj91legss
Yes it will. Its the combo I put in a 91 I sold a year or so ago.
If you happen to need a set of 2.0 head gaskets, I have some for sale in my post in the parts shed.
Posted: Fri Jul 31, 2015 4:17 pm
by bcmaxx
cj91legss wrote:Yes it will. Its the combo I put in a 91 I sold a year or so ago.
how did it turn out? did you have to use the 2.0 head gaskets?
Posted: Fri Jul 31, 2015 4:19 pm
by cj91legss
It ran great. I used the 22t gasket. I should have used the 205 gasket because of the difference in cylinder size and the fire ring. But it ran fine.
Ended up selling the car, to my knowledge the guy still has it.
Posted: Fri Jul 31, 2015 6:19 pm
by Alphius
Yes, you really should match the head gasket to the cylinder bore. Also make sure the combustion chamber won't at any point be larger than the bore.
Posted: Fri Jul 31, 2015 7:11 pm
by bcmaxx
Alphius wrote:Yes, you really should match the head gasket to the cylinder bore. Also make sure the combustion chamber won't at any point be larger than the bore.
ok thanks. i think the 2.0 gaskets/bore will match the ej22t heads well
Posted: Thu Aug 06, 2015 7:13 am
by bcmaxx
So the 2.o wrx gaskets are a perfect fit.....but.... block 2 little square hole tot and center of the combustion chambers and also two very small holes near the bottom outside edge. Anything to worry about?? They seem to be a better fit and line up much better than the aftermarket 22t head gaskets
Posted: Thu Aug 06, 2015 4:06 pm
by cj91legss
Show us an image.
Posted: Thu Aug 06, 2015 5:00 pm
by bcmaxx
they have the same fit as the aftermarket ej22t head gaskets, block the same holes, so maybe it isnt a problem?
Posted: Thu Aug 06, 2015 9:41 pm
by bcmaxx
didn't want to risk blocking off the 4 ports, one I believe is to help the exhaust valve area, got some super duper drill bits and drilled 8 holes
Posted: Tue Aug 11, 2015 3:42 pm
by kaszlarz
I have a question
EJ22 SOHC block with EJ20G DOHC heads - this setup will be work ??
Wysłane z iPhone za pomocą Tapatalk
Posted: Tue Aug 11, 2015 4:40 pm
by bcmaxx
kaszlarz wrote:I have a question
I think this will net an even higher compression ratio than my setup. I'm already just over 9. If you could massage and cc the combustion chambers possibly? I'm sure its been done
Posted: Mon Aug 17, 2015 8:04 am
by bcmaxx
And done!! Break in time
Posted: Thu Aug 20, 2015 2:57 pm
by cj91legss
Nice!!!
Posted: Mon Feb 22, 2016 1:08 am
by Sinix3
n/a or turbo block?? iv been looking into this aswell i have late g heads off an sf5 forester. and a 22t legacy that im doing this same thing.. i was told with 20g heads on a 22t it would be around 7.7:1 with stock thickness gaskets
