Are cam seals for a bc legacy era ej20g (2 bolt coils) the same as ej25d cam seals?
Does anyone have the part number for these cam seals?
Whats the Torque spec for cam bolts (all 4 cam gears are metal on this engine)??
Part number for 93 BC Legacy Ej20gn cam seals
Re: Part number for 93 BC Legacy Ej20gn cam seals
25D cam seals and the torque spec is 55-61 ft-lbs.susiemk wrote:Are cam seals for a bc legacy era ej20g (2 bolt coils) the same as ej25d cam seals?
Ft-lbs or inch-lbs?cj91legss wrote: 25D cam seals and the torque spec is 55-61 ft-lbs.
55-61 ft-lbs seems high for a 6mm bolt.
Haha I misread and thought cam gears my bad. Off the top of my head it's a light torque.
