91 MT IAC?
Snorkus, filters, throttle bodies and intake manifolds.
moelawe
91 MT IAC?
Post by moelawe » Mon Feb 11, 2019 4:58 am
I have a '91 EJ22 in a VW Vanagon that came from a JDM Legacy. I have been having rough idle issues for about a year and I have tried everything that I can think of. Thanks to you fine folks, I have been able to trace the issue to the IACV solenoid. As I am sure you all know, the 91 MT IACV is a short-run part (I believe only 90-91) and I am having a difficult time tracking down a replacement solenoid. Also, the '91 MT two prong IACV solenoid is only compatible with the Hitachi ECU.
I do have access to a 92 or 93 parts Legacy with the three prong IACV and the JECS ECU to match (the car is also a manual). My question is: Is it possible to swap the IACV (valve and solenoid) from the 92/93 as well as the JECS ECU from the 92/93 into my van and not cause myself a lot of issues? Thank you in advance!
rallyak
Re: 91 MT IAC?
Post by rallyak » Mon Feb 11, 2019 7:58 am
I too have a 90 MT with the same IAC and I did what your thinking of doing. I changed the ECM from a 93 legacy, the IAC and the MAF to match. All my idle issues went away and runs like a different car. I should have done it years ago. I didn’t have any issues with wiring it was completely plug and play.
Charles
moelawe
Re: 91 MT IAC?
Post by moelawe » Mon Feb 11, 2019 2:52 pm
Thank you for your help! Looks like I'm headed to the scrap yard today.
carfreak85
Re: 91 MT IAC?
Post by carfreak85 » Mon Feb 11, 2019 5:13 pm
Why not just clean the IAC? There are several tutorials out there both for the legacy and the later imprezas. It's pretty darn easy.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon
1984 GL-10 Turbo-Traction Hardtop
1987 RX coupe
1987 RX Type RA
2002 WRX sedan
Re: 91 MT IAC?
Post by Legacy777 » Mon Feb 11, 2019 6:37 pm
The injectors are also different between ECU's and you really should change the injectors.
My suggestion would be to get the IAC, ECU, MAF, & injectors with fuel rails.
1997 Impreza OBS
rallyak
Re: 91 MT IAC?
Post by rallyak » Tue Feb 12, 2019 6:43 am
Yes, the injectors are different but air/fuel is still on the rich side even though the gray ones are smaller. In my car I’ve cleaned the IACV hundreds of times along with the two small springs and the solenoid on the top. I have a few laying around and tried three different ones and never seem to work properly. Not sure why Subaru made an odd ball IAC for 5 speed cars in 90-91.
Charles
