Engine enamel
Engine enamel
Is it okay to use this stuff on the intake manifold?
If this is sti red then yes you do
There's an etching primer for aluminum that you should use first so the paint doesn't flake off. I forget the name of it, but I believe there was a thread on it before if you search.
look who's back
I just had the intake off last weekend.....the parallel fuel mod is a little more involved on our cars......mainly because the wonderful fuel adapter that they use on the scoobymods site is gone......If I would've had a second car I probably would've tried to rig something up. My reasoning was that for a n/a motor it wasn't that critical.
