So I bought one of those things on Ebay that you hook up to your Air Intake Temperature sensor and by turning the knob up or down you can either go rich or lean.
Only problem was that we do not have an Air Intake Temperature sensor on our Subes. Can I still use this thing somehow on the MAF? It has just two wires that go to a knob. Brand name is Power King.
Thanks for any help.
Enriching the air/fuel ratio with aftermarket do-hicky help
No, I'm pretty sure you can't use it on the MAF sensor. If the description said you could, get the seller to give you your money back.
If you really want to try it you could probably use it to modify or replace the coolant temperature sensor, which would similarly affect your air/fuel ratio.
My suggestion though is not to use it at all. It's going to trick your ECU a little but not enough to make it work well.
it won't work, send it back.
If it's one of those smart ecu's it may just make it's own army, train, and then go to all out war! You may want to return it soon before the ecu turns against the rest of the car.
-Ryan
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
