who's done a catch can setup on there car? I wanna see some pics of it so i can have an idea of what to do.
Thanks.
Logan
Catch Can
Catch Can
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Here's mine. You can't see everything I've done, but I ended up using a non-turbo IAC hose to connect the crankcase breather around the turbo so I could hook it up to the catch can.
http://main.experiencetherave.com/subaru/images/td05/07
You can kind of see the hose in these pictures
http://main.experiencetherave.com/subaru/images/td05/04
As for whether it works. I'd say yes.
http://main.experiencetherave.com/subar ... fault2.htm
I since put some mesh in between the inlet & outlet to help the oil condense and drop out.
http://main.experiencetherave.com/subar ... /catchcan/
what size of greedy catch can did you use? they have a couple different sizes (9mm, 15mm).
Ummm....I think it was the 15mm one.
BTW, I'm quite amazed at what the mesh has done to help condense the oil. I just drove about 2,000 miles in four days, and I've got about 1.5" of oil registering in the catch can sight thingy. I've got a picture, but I've got to get it up to my server. When I do, I'll post it.
Here's pics of the oil in the catch can sight glass.
http://main.experiencetherave.com/subar ... chcan1.jpg
http://main.experiencetherave.com/subar ... chcan2.jpg
I can clearly see where the hose that goes from the intake goes into the catch can, but where does that other hose go to? Looks like it moves toward the turbocharger? Where does it end? Thanks.
It comes from the port on the back of the engine block
http://main.experiencetherave.com/subar ... P_6894.JPG
http://main.experiencetherave.com/subar ... P_6898.JPG
http://main.experiencetherave.com/subar ... P_6900.JPG
Thank you
