Is there an intake I can use that the IAC valve isn't in the way of the stock WRX/STI BPV on the 06-07 WRX TMIC? It's also got to fit an straight inlet intake under the manifold. I'm thinking I'm shit out of luck here with these constraints because the only ones I can think of that fit these criteria are WRX and STI manifolds which don't have IACs or they're built into the throttle body I guess and I don't think they can be used with my ECU.
Any insight would be great. My issue is the stock BPV and the small diameter piping I have to it are too restrictive and it's causing compressor surge and I don't like it. The stock WRX/STI BPV is huge in comparison. The valve is larger as well as the diameter of the piping.
Intake That Clears WRX/STI BPV
