Taking off my intake manifold
Nibbib
Post by Nibbib »
Hi there I'm in the middle of taking of my intake manifold I think I have everything unbolted and unplug but I'm still having resistance lol.
I don't need to have the manifold completely out of the car just enough so I can fix my broken hoses..
Any advice would help
Nibbib
Re: Taking off my intake manifold
Post by Nibbib »
And I found out that the two nipples for the throttal body aren't even there... Can someone tell me where they tie into or go so I can get the right hoses and install
James614
Post by James614 »
Those are probably for the coolant. Many people bypass it to keep intake temps cooler. There's no reason to put it back. Mine are capped off too.
Make sure you IAC's water lines are disconnected. There's gonna be a decent amount of resistance from the old gaskets.
Nibbib
Post by Nibbib »
Hmm I didn't know that the iac had water lines.
And I can fully move the manifold but can only lift it up maybe 1/2" or 3/4" if I really pull
The wiring harness has plugs going to the two temperature senders on the crossover pipe, as well as one going to the oil pressure sensor right under the alternator. You.sure they are all unplugged?
Nibbib
Post by Nibbib »
I didn't get those ones and I'm not sure I'll be able to with my big ass hands...
Nibbib
Post by Nibbib »
Thanks for the help got it off it's still a pain in the ass with the turbo and power steering pp still on lol
Nibbib
Post by Nibbib »
Just wondering what would be easier to do with installing the PVC hoses before I put the manifold back in or after
alexandermf
Post by alexandermf »
Definately be easier to replace without mani on but possible to do with it on as well
Nibbib
Post by Nibbib »
yeah i was thinking that but don't some of the hoses have to go through the manifold?
alexandermf
Nothing you can't reroute to your liking...
Nibbib
Post by Nibbib »
yeah lol but i bought the whole oem system from my local subaru dealer.. which isn't cheap.... ($300)
robertpaige
Post by robertpaige »
It will still be easier to assemble everything without the manifold.
