45° air box with velocity stack questions
Posted: Thu Apr 24, 2014 8:27 pm
I've looked through most of the threads on the airbox mod.
But i have a couple questions for my set up.
First.
I'd like to know if leaving this white piece in the bottom part of the box is beneficial? (With or without the velocity stack)
Second.
I'm installing a velocity stack here.
And,.
The velocity stack I have is 2&3/4" ID.
The size of the hole in the box is 3&1/2" dia..(pictures below).
So I'm wondering, if putting the velocity stack on. will actually have a negative effect on what im tryin to accomplish with the bigger intake hole.
I was also thinking if I install the stack and the extra inlet elbow, (as Josh did on his..)
would that provide saficient airflow, With the smaller diameter stack?
I am also going to install the golden metal velocity stack right before the maf..So ill be flowing real smoothly..
Any thoughts that could help me or answers would be great. Thanks in advance.
Sent from my SCH-I545 using Tapatalk
First.
Second.
And,.
