turbo inlet elbow repair
Posted: Thu Jun 05, 2014 4:28 am
by turbo970
dont know why but my one year old hard to find elbow is splitting at the hard line inlets. can i do a repair with plastic plumbing pieces?
Re: turbo inlet elbow repair
Posted: Thu Jun 05, 2014 3:16 pm
by cj91legss
I used some RTV on the insides of my elbow when putting my engine together. It seems to help. Mine was pretty cracked.
Posted: Thu Jun 05, 2014 3:32 pm
by turbo970
i did that so far. but if it gets worse i thought of using hard plastic to fix it or find one not made of rubber
Posted: Thu Jun 05, 2014 3:37 pm
by cj91legss
You could spend a couple hundred and go the samco route, but it's too expensive...
Posted: Thu Jun 05, 2014 7:06 pm
by robertpaige
Screw that, just make a custom metal elbow, and attach it to the turbo inlet with a silicone coupler.
Posted: Thu Jun 05, 2014 7:33 pm
by ride_child
http://bbs.legacycentral.org/viewtopic.php?f=1&t=52328
we should probably do a group buy on these cast metal elbows!
Posted: Thu Jun 05, 2014 8:05 pm
by turbo970
if its not to pricey i'll invest in one. i'm more upset that i got a year on the elbow and it split already
Posted: Thu Jun 05, 2014 8:34 pm
by SILINC3R
Look at my bulid, you might be able to go that route.
build thread
Posted: Thu Jun 05, 2014 9:01 pm
by turbo970
what all ya use to make that? and where and i get a tmic blow off valve adapter like yours?
Posted: Thu Jun 05, 2014 10:29 pm
by robertpaige
On eBay, seller is WyntomN.
http://stores.ebay.com/Wyntonm-Perform? ... &_from=R40
Posted: Fri Jun 06, 2014 12:42 am
by SILINC3R
turbo970 wrote:what all ya use to make that? and where and i get a tmic blow off valve adapter like yours?
All the info should be on my build thread.
Posted: Sat Jun 14, 2014 6:35 pm
by 93legacySS
Use a q bond. Best stuff out there!!!
Posted: Sat Jun 14, 2014 7:59 pm
by turbo970
so could i use brass fittings and use the q bond to seal things up?
by turbo970
so could i use copper fittings and use the q bond to seal things up?
