Fuel cut at high rpm, possibly maf?
IllaKong
Post by IllaKong » Sun Apr 07, 2019 7:48 pm
Newly swapped 22t block with 25d heads, using roubtune 550, experiencing fuel cut at high rpms(5 or more), wondering if anyone has experienced this? I heard it could be the maf, currently using the stock one still.
Re: Fuel cut at high rpm, possibly maf?
Post by mike-tracy » Sun Apr 07, 2019 11:47 pm
If you're using the aluminum MAF, you need to switch to the plastic 92-94 (NA) style. Also, if there's no check engine codes, I'd guess you have a vacuum leak.
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
