headlights - suggestion
vypa
Post by vypa »
since alot of you seem to have the headlight foggin goin on i thought id share my solution to it... if you can get GS40 (that scratch removing stuff they sell on TV and all) just use it on your headlights by rubbin it on there in a circular type motion then rinse any excess off. if you dont have GS40 just about any rubbing compound seems to work.
Post by entirelyturbo »
Okay, but does the yellowing come back? I know many ways to make it go away temporarily and then come back...
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
vypa
Post by vypa »
yea after a couple weeks or so it starts to... but not nearly as bad as it was
I presume a gritty rubbing compound to "scrape" the fogging off, right?
vypa
Post by vypa »
GS40 is pretty smooth and it works ok... the grittier may work better if yours are really fogged... y dont u experiment and share with us :P
:lol: :lol: I just might do that............. with the headlights off the car, of course...
ericS2the6
Post by ericS2the6 »
i just used some wet sanding followed by a little 3m plastic polish stuff today, and they looked pretty good tonite. i havent seen them in the day tho.
boostjunkie
Post by boostjunkie »
But nothing beats a new set of headlights. Geez, these ones Adam put on the car before he gave it to me are better than the lights on my old GT!!
Much better light output!!
what did adam put in?
I know he just put in HID's on your old car.......I wouldn't mind having a set.....or a set of these ;)
http://orderxenarc.sylvania.com/orderxe ... 5200312110
boostjunkie
WOAH!! That would fit perfectly in the bottom "foglight" openings!!
Adam, put soome PIAA superwhites in the headlights, but I think the real gain was through installing new headlight assemblies. He also put some secondary CATZ foglight/driving light combos. They come with both a yellow fog lens and a white driving lens. Anyways, these compliment the headlights very well.
I dunno, but my light output is better than my friend's MK4 Jetta.
I've been wanting to rewire the headlight assemblies and wire them directly to the battery for better amperage draw. Also....I need to put on the new headlight lenses I got.....the ones I have are yellowed beyond belief...and are pitted and shit.
Plus if I decide not to go to the HID's, I should probably replace the bulbs I currently have. They are still working, but not sure if they have seen better days.......I'll prob get one and just see which one is brighter.
Probably would get the silverstars from sylvania.
boostjunkie
I'd put in those new lenses in first. I guarantee you'll see a difference.
Yeah I know.....I'm waiting for the new hood & bumper first......
boostjunkie
With the new hood and bumper, is there a turbo legacy swap in your future? serious on the NASIOC boards is selling his
ummm I had thought about this.....the main reason was that I needed a new hood due to a little accident......so....why not get a turbo legacy one ;)
I can probably pick up a buddy's 94 turbo legacy for under 5k. To do a turbo kit, and to do it right......I'd easily spend that. So my thinking as of now.....why spend money on one car, when you can spend less or the same and have two :)
I used Mother Mag & Aluminum polish. It did a great job of removing the yellowing, and most of the fogging... If I didn't have a new light to compare it to, I'd say it looked as good as new.
Unfortunately, I do have another light... The other one on the same car!
I'll have to see if GS40 works better at equalizing my headlights. Thanks for the tip!
