Moderators: Helpinators , Moderators
vypa
Posts: 104 Joined: Fri Dec 27, 2002 3:00 am
Post
by vypa » Fri Jan 17, 2003 1:50 am
anyone kno how difficult it is to change the backlight bulbs in the speedo/tach and AC? and the best way to get at them?
thanks
Brian
http://vypa.homestead.com/index.html
ciper
Posts: 4388 Joined: Tue Oct 15, 2002 8:16 pm
Post
by ciper » Fri Jan 17, 2003 2:13 am
Take the dash cover off that surrounds the gauges. Then remove the cluster. The lights are mounted on the back of the cluster for the illumination.
The lights that indicate turn signals, doors and gear position are in the front so you will have to take the cluster apart.
vypa
Post
by vypa » Fri Jan 17, 2003 2:18 am
ok what about the lights behind the climate control stuff tho? can those be changed?
Brian
ciper
Post
by ciper » Fri Jan 17, 2003 3:58 am
Hmm, I would assume so but I never took that apart.
When taking the dash apart realize that screws hide behind the vents and in other strange places. Dont force it if it doesnt come out easily.
I know that the bulbs on the buttons for air/defrost/cruise are replacable.
scoobiedoo22
Posts: 144 Joined: Wed Oct 16, 2002 9:04 pm
Post
by scoobiedoo22 » Fri Jan 17, 2003 4:06 am
The bulbs for the heater control and a/c are located ON the circuit board behind the switches, the bulbs lock/thread into the board. They are Subaru specific, you will have to go to a dealership to get them, all you have to do is bring the old ones in and they should have replacements in stock. About removing the instrument cluster, do be careful, the clips break easy. Hope this helps, john k
1991 Legacy SS 5-Speed
1999 Impreza 2.5RS Coupe
vypa
Post
by vypa » Fri Jan 17, 2003 5:10 am
ahh thanks alot guys! much help... ive taken the dash out... once.... and it is a paint... while im back there replacin a couple bulbs i wonder if they make blue.... i personally dont care for the green
Brian
ciper
Post
by ciper » Fri Jan 17, 2003 7:06 pm
I once saw a bag of blue "Condoms" for sale that was intended to convert the color of your light. Maybe you could use the same?
