So i have had a small drip when it rains. It comes from between the two door seals at the corner and drips on to my leg. So i finally got pissed and ripped out those wonderful black tracks that run the side of our cars. and I find a screw missing and the foam that is supposed to keep the water out pretty much gone and the inevitable rust.
LUCKY ME.
You cant find good replacement parts, so i scrub the rust out, put a coating of anti-rust over it and try and figure out what to use to seal the strips as I can't get the replacement foam . Probably going to be just a nice tube of silicone.
Sorry Subaru but the window and roof seal design on this car sucks.
fixing gutter seals that were not meant to last 20 years
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Re: fixing gutter seals that were not meant to last 20 years
hmmm, mine leaks a tad too on the driver's side when rains. I wonder if it's the same issue.
My fiance's 93 does it too...
Mine never used to untik I painted the roof and removed all that trim and gaskets to paint it. Leaked ,r since. Sunroof too. Sucks.
i have a front passenger leak above the window how in the world do i get that freaking outer black trim off!!!!
1993 legacy ss "Shela"
Glad to know I'm not the only one with that leak issue. I've tried silicone and it made it worse, not sure how that works lol.
Danny
The outer trim comes off like this: open both the front and rear doors. At the lowest points of the rubber window seals will be two small round clips. This is at the front and back of each window seal location - so eight clips in all. Loosen the visible screw at the lower left of the rear triangle rear window trim. ( this would be the drivers side. It would be lower right on pass side). Then slowly pull the window seal out of its tracks. This will expose small screws. Remove all screws. Then slowly from one side remove the seal tracks. This will expose more screws. These last screws hold the front two pieces of roof trim.
05 GD-STI
00- GF
05 GD-STI
00- GF
thanks scoob my repair manaul isnt clear on this.
