»  BC-BF Legacy Discussion »  Body, Chassis and Interior
#First Gen Legacy | Interior Refresh
Custom Search
Login | Register
Post new topic Reply to topic  [ 17 posts ]
Author Message
 Post subject: First Gen Legacy | Interior Refresh
PostPosted: Wed Jan 14, 2015 9:43 pm
After a long series of failed attempts at having someone do this for me I have decided to just do it myself. I have two extra door cards, so this first one is a test so I can figure out exactly what methods I want to use for the door cards I will use.
My game plan is to clean and dye the door cards, remove the inserts (which is a pain in the ass) and wrap them in either leather or alcantara.
Here is what I started with:
After dye:
The next step was to remove the insert. Being such an old door card the insert is actually glued down, as opposed to being removable like newer vehicles are. For this one I used a heatgun, scraper and a lot of time. Going forward I will use something along the lines of a hacksaw blade or something I can slide under the insert to cut the glue.
Here is the removed insert:
I am laying fiberglass over the back of the insert to make it more rigid when I wrap it. I am torn weather to fiberglass the front of it and smooth down, or just wrap over top of the original fabic. Thoughts anyone?
Profile  Offline
 Post subject: Re: First Gen Legacy | Interior Refresh
PostPosted: Thu Jan 15, 2015 3:15 am
That's because these cars didn't need to be pulled apart to fix stuff all the time! Nice work!
Legacys are like potato chips-you can't stop at one!
Profile  Offline
PostPosted: Thu Jan 15, 2015 5:45 pm
Thanks so much! Cant wait to get more done!
Profile  Offline
PostPosted: Tue Jan 20, 2015 4:36 pm
I had great success removing the inserts from the two rear doors. Not a single tear!
Profile  Offline
PostPosted: Tue Jan 20, 2015 7:11 pm
Excellent work!
I'm excited to see how the final product turns out.
1997 Impreza OBS
Profile  Offline
PostPosted: Mon Jan 26, 2015 6:47 pm
what dye are you using?
Profile  Offline
PostPosted: Mon Jan 26, 2015 8:14 pm
Profile  Offline
PostPosted: Mon Jan 26, 2015 9:04 pm
I am planning on starting a similar project on my interior. Keep it up, I think I will do it the same way myself. What has to be done to layer fiberglass? Is that something I should have prior experience with?
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Profile  Offline
PostPosted: Tue Apr 07, 2015 7:46 pm
Not the greatest photo, but the two front door cards are cleaned up and dyed. I should probably get moving on finishing up the inserts pretty soon.
Profile  Offline
PostPosted: Tue Apr 07, 2015 7:48 pm
Fiberglass is a real pain in the ass, but as long as you can follow directions and have a little patience you shouldnt have any issues.
Profile  Offline
PostPosted: Thu Apr 09, 2015 11:09 pm
Hopefully I will get around to that soon. Did you have to replace the rubber trim that the windows roll down into? I should start stripping my interior in the next month or so and just want to get as many pointers as I can.
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Profile  Offline
PostPosted: Thu Apr 09, 2015 11:10 pm
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Profile  Offline
PostPosted: Sun Jul 19, 2015 5:09 pm
Still need to finish these up, paint is almost done on the car
Profile  Offline
PostPosted: Sat Nov 21, 2015 6:25 am
Real good work, please keep the information and pics coming.
Profile  Offline
PostPosted: Sat Nov 21, 2015 6:43 pm
Thanks man! It looks like I may be shit out of luck though. A bunch of my parts were stolen from my old house :(
Profile  Offline
PostPosted: Mon Apr 25, 2016 4:58 pm
Took this out and cleaned it up. Needed to take it out for manual conversion anyway:
It's in really good shape aside from some discoloration, and the armrest is beat up. One question I have though, is the shifter surround different between the auto and manual?
Profile  Offline
PostPosted: Mon Apr 25, 2016 5:18 pm
The shifter surround is indeed different
1992 Legacy SS 5mt, reasonably modified ;)
Profile  Offline
Who is online
Users browsing this forum: No registered users and 3 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
