»  BC-BF Legacy Discussion »  Body, Chassis and Interior
#Aftermarket steering wheel help!
Custom Search
Login | Register
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Aftermarket steering wheel help!
PostPosted: Wed Feb 10, 2016 6:49 am
I installed an nrg short hub in my 92 legacy sedan (base) and I'm having 2 issues, the first one is that my turn signals don't click off after I turn they just stay on is there anything I can do to fix that? It's just annoying turning them off after I turn lol. The other issue is that the horn does not work. Everything worked fine with the stock wheel. Any input helps! Thanks in advance
1992 Subaru Legacy sedan L (Green), Garage whore
1992 Subaru Legacy sedan L, bad tranny (White), lawn ornament
1991 Nissan Sentra R.I.P
2001 Pontiac GrandPrixGT Supercharged, R.I.P. ;_;
Profile  Offline
 Post subject: Re: Aftermarket steering wheel help!
PostPosted: Thu Feb 11, 2016 10:44 pm
http://forums.nasioc.com/forums/showthr ... ?t=1139576 here's a write up on how to get the horn to work and how to get the auto off signal lights to work
Profile  Offline
PostPosted: Thu Apr 07, 2016 6:26 pm
Using an appealing wheel from another subaru is a less painful approach and virtually guarantees that things will work
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
