Air bag question
Posted: Fri Aug 12, 2016 10:11 pm
by icrman
Does anyone know the squib resistance ? Like if someone has installed an aftermarket steering wheel and doesn't want the light on all the time.
Re: Air bag question
Posted: Thu Aug 18, 2016 5:32 pm
by Danny-G
You can just unplug the light behind the cluster
Posted: Sun Aug 21, 2016 6:34 pm
Or remove the airbag computer
Posted: Sun Aug 21, 2016 6:57 pm
by JSkeezLegacy92
When you take apart the cluster, behind the airbag plug is a little motherboard that is hidden behind a piece of plastic. That motherboard tells the car when to keep that airbag light on. You can just remove it completely or just don't plug in that connector that goes to it. It'll keep the light off that way. Even with the computer taken out and the wires cut, that little motherboard tells it when to go on
