Help on 1st gen front crossmember specs.
Posted: Thu Feb 02, 2017 5:58 am
Asking if anyone has a 1st gen front crossmember laying around that you would be willing to pull some measurements off of...shouldn't matter between the turbo and n/a as they should spec the same besides the up pipe divit. I have a crossmember that was pulled from a wrecked 91 turbo (hit hard passenger side front) that I want to prep and have powdercoated to replace my current (slightly rusted) one...but I want to know if it's out of spec and even worth my time as it appears slightly splayed inward on the p. side.
Here are the measurements I pulled today, starting from the front most (in-line with the motor mount holes) stud plate mount holes. Measurements were taken from bolt holes center point to center point across the crossmember.
Front bolt holes - 33-3/4 inches / 856mm
Middle bolt holes - 33-1/4 inches / 845mm
Rear bolt holes - 32-7/8 inches / 833mm
As you can see, it's splayed and from what I think or imagine, the front frame rails on our cars should be parallel.
Thanks for the help!
