»  BC-BF Legacy Discussion »  Body, Chassis and Interior
#A.c. Compressor doesn't fit
Custom Search
Login | Register
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: A.c. Compressor doesn't fit
PostPosted: Sat Mar 18, 2017 11:53 pm
Looking to find a later model a.c. Compressor that will fit my 98 ej25d and bolt up to the existing hoses on the 91 legacy l that the engine is in. The 91 compressor and mounting bracket don't work on the ej25d, won't physically fit due to interference with the intake manifold.....help please!
Profile  Offline
 Post subject: Re: A.c. Compressor doesn't fit
PostPosted: Sun Mar 19, 2017 12:30 am
I'm 99% sure the newer compressor wont bolt up to the stock compressor lines. Even 1st gens had 3 different kind of fittings that weren't interchangeable.
1992 Legacy SS 5mt, reasonably modified ;)
Profile  Offline
PostPosted: Sun Mar 19, 2017 12:34 am
If you gotta keep AC, I would grab the one that came on your ej25d and have an AC shop adapt it to your car's lines.
Profile  Offline
PostPosted: Sun Mar 19, 2017 12:43 am
Custom adaptation sounds like what needs to happen then, can't wait see how much that costs....
Profile  Offline
PostPosted: Sun Mar 19, 2017 12:58 am
Winestone Cowboy
Just take it out and run "4/55" AC
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 450k miles and climbing
Profile  Offline
PostPosted: Wed Mar 22, 2017 1:06 am
It's usually fairly cheap to have A/C lines made. I have paid around $20-30 a line for that sort of stuff before.
2005 Legacy GT Limited Wagon 5-Speed. Stock-ish ;)
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
