Daikei S-501 Hub Adapter
Subiekid94
Post by Subiekid94 »
I was looking at getting a Grip Royal wheel and I need a hub adapter, I know Momo makes one but I've heard you lose your horn and turn signal shut off, I've also read on NASIOC that Daikei makes a hub that uses the OEM horn and turn signal controls, and has an airbag light shutoff for a 1st gen Imprez. Are there any better hub options out there?
mr.blub.blubs142
Re: Daikei S-501 Hub Adapter
Post by mr.blub.blubs142 »
I run a nardi hub. I got the turn signals to still auto shut off by cutting off the plug on the clock spring for the horn and cruise. No horn sadly though.
