»  BC-BF Legacy Discussion »  Misc
#In desperate need of help (92 legacy sport [stock])
Custom Search
Login | Register
Post new topic Reply to topic  [ 13 posts ]
Author Message
 Post subject: In desperate need of help (92 legacy sport [stock])
PostPosted: Sun Jul 09, 2017 5:26 pm
Ok, so i recently bought a 1992 subaru legacy sport with a 5 speed. It runs and drives, but not smoothly. I am getting error codes 42 and 35. Tps (which i just replaced) and i assume mas. My symptoms are.... car idles at 1500 when warm and barly idles at 500 when cold. I need to constantly pulse the throttle to keep it running until it gets warm, and even then it wont idle untill i have driven it at least 5 minuts. I also only get about 10-14 mpg (i know, American db). For this i am referencing the picture with the circle. When that hose is un kinked, the engine idles at 2500 to 3k, and when the throttle is blipped it will stay at the engine speed it topped at. When kinked i get said symptoms. Other symptoms include the engine cutting off sometimes when i hit boost, and the clutch not grabbing well. On that sub topic, the clutch is new. When i try to shift into reverse right after pressing the clutch it grinds heavily. Also while driving normally, with the clutch fully depressed it will grind untill fifth. Another thing i have noticed is that there are a few broken things. I am not a mechanic but i know my way around a wrench. The picture with the newer engine bay (green) will have all of the things that are broken or jerry rigged circled.
Oh great hive mind of the internet, share your infinate knowledge with me!
Sent from my SM-G920V using Tapatalk
Profile  Offline
 Post subject: Re: In desperate need of help (92 legacy sport [stock])
PostPosted: Sun Jul 09, 2017 5:34 pm
Ps, when the hose is fully kinked it idles at a normal 750 rpm. Oh, and here's a better pic of the bay.
https://uploads.tapatalk-cdn.com/201707 ... fe856a.jpg
Profile  Offline
PostPosted: Mon Jul 10, 2017 2:23 am
The low idle when cold sounds like a coolant temp sensor. Start with that, easy to test. There's one for the gauge and one for the ECU, you'll want to test/replace the latter (2-wire).
Profile  Offline
PostPosted: Mon Jul 10, 2017 6:21 pm
Welcome to the BBS.
Why is/are you kinking the hose going to the idle air control valve? That would likely explain why the idle is poor.
1997 Impreza OBS
Profile  Offline
PostPosted: Tue Jul 11, 2017 4:36 pm
Legacy777 wrote:
Welcome to the BBS.
When the hose is not kinked at all, the engine will start, idle at 2k, and stay where it was reved to. If i didnt kink it, i would have multiple issues on the road.
Profile  Offline
PostPosted: Tue Jul 11, 2017 4:40 pm
Ill try to check/replace it when i get payed next. I kind of spent all of my money on car parts when i bought it.
Profile  Offline
PostPosted: Tue Jul 11, 2017 5:27 pm
xxthatcrazyhobox wrote:
Legacy777 wrote:
Welcome to the BBS.
In my opinion you are trying to fix a symptom rather than a cause. In troubleshooting you need to fix the root cause of the problem. Subaru did not intend for the IAC hose to be kinked.
If I'm understanding you, if the hose is not kinked the idle stays at 2,000 rpm. What other issues do you have? Have you tried unplugging the electrical connector from the IAC valve to see if the behavior is different or if the idle stays at 2,000 rpm?
1997 Impreza OBS
Profile  Offline
PostPosted: Wed Jul 12, 2017 2:18 am
Legacy777 wrote:
Welcome to the BBS.
Kind if. I unplugged the batt and un kinked the hose. But it was only unplugged for a max of 15 minuts.
All of the symptoms should be listed in the post.
Profile  Offline
PostPosted: Wed Jul 12, 2017 3:04 am
Your post is not clear, which is I asked the question about the issues/symptoms occurring when the hose is not kinked.
Do these symptoms occur with the IAC hose kinked or not kinked?
Same question about these symptoms.
1997 Impreza OBS
Profile  Offline
PostPosted: Thu Jul 13, 2017 8:32 am
It sounds like your idle air control valve is stuck open or malfunctioning in some way.
2002 Impreza WRX
1994 Legacy TW
1999 Impreza OBS
Profile  Offline
PostPosted: Sun Jul 16, 2017 9:17 am
These happen when the hose is kinked. It is un drivable when it is un kinked.
Profile  Offline
PostPosted: Sun Jul 16, 2017 11:31 am
What he said.
1997 Impreza OBS
Profile  Offline
PostPosted: Fri Jul 21, 2017 3:14 pm
Legacy777 wrote:
What he said.
No, i havent thought of unplugging the iacv yet. Ill try.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 2 guests
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
