»  BC-BF Legacy Discussion »  Misc
#Has anyone made an onboard air compressor?
Custom Search
Login | Register
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Has anyone made an onboard air compressor?
PostPosted: Tue Sep 01, 2015 6:43 pm
I pulled the air compressor system out of my 94 TI wagon. I was wondering if anyone had made an on board air compressor system with these parts? If so what kind of troubles did you run into if any?
1992 Legacy L Wagon 4WD Auto 219K
1994 Legacy SunSport Wagon FWD 249K
1994 Legacy Ti 4WD Wagon 5speed 182K (162K on engine)
Profile  Offline
 Post subject: Re: Has anyone made an onboard air compressor?
PostPosted: Tue Sep 01, 2015 9:11 pm
If your planning on filling tires and such, you will find the OEM compressor too small. It's not designed for that much volume or to run for extended periods. The volume of air in all 4 springs is likely much less than then even just the spare tire.
I have adapted a larger, more traditional compressor to the factory mounting bracket to supply air to a small tank in the trunk. It worked well before the car got sideswiped.
Sent from my SM-N900V using Tapatalk
Profile  Offline
Who is online
Users browsing this forum: No registered users and 7 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
