»  BC-BF Legacy Discussion »  Misc
#Gauge mounting 91 leggy
Custom Search
Login | Register
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Gauge mounting 91 leggy
PostPosted: Tue May 09, 2017 1:53 am
I want to add gauges in my leggy wagon, looking for good mounting spots open to all ideas. Also, any ideas on good egt gauge package? Thanks in advance.
Profile  Offline
 Post subject: Re: Gauge mounting 91 leggy
PostPosted: Tue May 09, 2017 3:42 am
Most people do an a-pillar mount or replace the center A/C vents with a plate for gauges.
I've also seen people put them down by the stereo, but I'm not a huge fan of that positioning.
Another decent option is a gauge cup attached to the steering column trim in front of the speedo or tach.
2005 Legacy GT Limited Wagon 5-Speed. Stock-ish ;)
Profile  Offline
PostPosted: Tue May 09, 2017 4:14 am
My current setup
93 fwd beater wagon
93 tw build in progress
Profile  Offline
PostPosted: Tue May 09, 2017 1:26 pm
Is there someone who actually makes a good A-pillar mount for the first gen cars? I would be content to go that route to avoid hacking up the ever so necessary air conditioning outlets. The A-pillar mounts are fairly easy to work with if made properly.
Profile  Offline
PostPosted: Wed May 10, 2017 3:19 pm
If you do some searching, there's an early 90's Honda application that works almost perfectly in the firstgen Legacy. There aren't any direct-fit parts.
Profile  Offline
PostPosted: Wed May 10, 2017 7:28 pm
Winestone Cowboy
I had good luck with a Nissan 240 A pillar shell a while ago
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Profile  Offline
PostPosted: Wed May 10, 2017 8:22 pm
Alphius is correct. The early 90s civic and crx pods should work well
93 fwd beater wagon
Profile  Offline
PostPosted: Fri May 12, 2017 5:27 am
Thanks for the info Alphius, I will look around and see what I can find...I am also considering trashing the ashtray and mounting the gauges there, I know its not ideal but its not a race car, so being in the line of sight is not as important. I can glance down at them at stoplights if I cant manage it any other time. zzzzzz :lol:
Profile  Offline
Who is online
Users browsing this forum: No registered users and 7 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
