Page 1 of 3
Subaru Manuals, Service Bulletins, and more
Posted: Sat Dec 06, 2003 5:42 am
UPDATE: 1/2/2020
I am in the process of upgrading my server and in doing so have discovered some issues with filenames that contain symbol ampersand "&". So I have had to rename anything with an ampersand in it to and. So if you happen to get a server error while trying to access anything, please replace the '&' with the word 'and' (remove quote marks). I will try and review the server logs and update links that refer to the old files. I tried to setup an automatic redirection, but wasn't able to do that.
Thanks for everyone's understanding
Well....I wouldn't want you guys to think I don't like you and not get you a Christmas present.....so I'm going to inundate you with info.
Larry posted a link over on the BC-BF List for these parts & service manuals. This guy apparently scanned them in because he used an EJ22 motor in his airplane. Well the scans were a little hard to navigate....so being me, I added bookmarks to the pdfs so you have a nice index structure to see what's all in the pdf. The FSM & Parts manuals only include the engine/electrical pages, but contain most of the important stuff.
Please right click and save the pdf's. Thanks!
Note: I've updated all the files so the bookmark index shows up automatically. If you're not sure what I'm talking about, and can d/l again, you'll see what I mean.
Here is the root link for all the service manuals
https://www.main.experiencetherave.com/ ... ual_scans/
1992 FSM (Engine & Electrical)
https://www.main.experiencetherave.com/ ... and_Elect/
Note: I added a scan related to the combination meter that wasn't previously in there. 9/9/2012
1992 Liberty FSM (FULL) (Overseas Legacy/Liberty manual)
NEW
https://www.main.experiencetherave.com/ ... SM_-_FULL/
1990-1994 Parts Manual (Engine)
https://www.main.experiencetherave.com/ ... _-_Engine/
1992 Service Bulletins
https://www.main.experiencetherave.com/ ... Bulletins/
Multi Year Subaru Service Bulletins
1990-1994 Legacy Parts Catalog - FULL
viewtopic.php?t=30531
Don't forget the other scans I already have there.
Also, some of you know this, but I have scanned my entire owner's manual as well.
You can look at each page or d/l a complete pdf file
https://www.main.experiencetherave.com/owner/
Spooled Up Racing FSM Collection
http://www.spooledupracing.com/download/Manuals/FSM/
Collection of 2005-2009 Legacy FSM's
http://people.csail.mit.edu/ilh/vacation/
A collection of A LOT of Subaru manuals; hats off goes to the folks over at sl-i
http://sl-i.net/FORUM/viewtopic.php?f=14&t=28539
Like I said, there's A LOT of info in these pdf's. The service bulletins have a lot of good info too.
Enjoy
NOTE: Please do not use file downloader programs to leach all the files from my server. It causes excessive traffic and slows connection speeds for everyone, including me. I reserve the right to terminate and/or ban IP addresses if I see excessive repeated connections.
Thanks for understanding.
Posted: Sat Dec 06, 2003 5:48 am
by mTk
Thanks!
MK
Posted: Sat Dec 06, 2003 6:11 am
Wow! Thank you so much! This is awesome.
Posted: Sat Dec 06, 2003 7:44 am
Now for the index of everything
Code: Select all
1990-1994 Subaru Legacy Parts Manual – Engine
* Illustrated Index
* Group Index
* Short Block Engine
* Gasket & Seal Kit (Engine)
* Cylinder Block
* Timing Hole Plug & Transmission Bolt
* Cylinder Head
* Piston & Crankshaft
* Flywheel
* Camshaft & Cambelt
* Valve & Valve Rocker
* Rocker Cover & Oil Filler Duct
* Timing Belt Cover (To Dec ’92)
* Timing Belt Cover (From Jan ’93)
* Oil Pan
* Oil Pump & Oil Filter
* Oil Cooler; Turbo (‘91MY)
* Water Pump; NA
* Water Pump; Turbo
* Turbo Charger System
* Intake Manifold; NA (’90 & ‘91MYS)
* Intake Manifold; NA (’92 & ‘94MYS)
* Intake Manifold; Turbo
* Air Cleaner
* Air Duct
* Fuel Pipe System
* Fuel Injector
* Engine Cooling System; NA
* Engine Cooling System; Turbo
* Throttle Body & Air Duct
* Alternator Bracket & V Belt
* Spark Plug & High Tension Cord
* Wiring Harness-Engine; NA
* Wiring Harness-Engine; Turbo
* Starter (1) MT (1.0KW)
* Starter (2) AT (1.4KW)
* Alternator
* Hose & Clamp (P.C.V.); NA
* Hose & Clamp (P.C.V.); Turbo
* Emission Cont System; Turbo
* Engine Electrical Parts
Code: Select all
* Table of Contents
* 1-1 Specifications
* 2 Engine Section Index
* 2-1 Emission Control System and Vacuum Fitting
* System Application
* Schematic Drawing
* General Precautions
* Crankcase Emission Control System
* Ignition Control System
* Evaporative Emission Control System
* Vacuum Fitting
* 2-2 On-Car Services
* Foreword
* Engine Compression
* Intake Manifold Vacuum
* Hydraulic Lash Adjuster
* Fuel Injector
* Oxygen (O2) Sensor
* 2-3 Engine
* Mechanism and Function
* General
* Timing Belt
* Belt Tension Adjuster
* Belt Cover
* Valve Rocker ASSY
* Cam Shaft
* Cylinder Head
* Cylinder Block
* Crankshaft
* Piston
* Specifications and Service Data
* Specifications
* Service Data
* Component Parts
* Timing Belt
* Cylinder Head and Camshaft
* Cylinder Head and Valve ASSY
* Cylinder Block
* Crankshaft and Piston
* Service Procedure
* Timing Belt
* Valve Rocker ASSY
* Camshaft
* Cylinder Head
* Cylinder Block
* Troubleshooting
* Engine Trouble in General
* Engine Noise
* 2-4 Engine Lubrication System
* General
* Lubrication Lines
* Oil Pump
* Oil Filter
* Oil Pan & Oil Strainer
* Oil Pressure Switch
* Component Parts
* Oil Pump
* Service Procedure
* Oil Pump
* Troubleshooting
* 2-5 Engine Cooling System
* General
* Cooling Lines
* Water Pump
* Mechanical Seal
* Thermostat
* Coolant Filler Tank
* Specifications
* Service Data
* Component Parts
* Water Pump
* Radiator and Radiator Fan
* Water Pipe
* Service Procedure
* Water Pump
* Thermostat
* Radiator
* Radiator Cap (Filler Tank Cap on Turbo Model)
* Radiator Fan and Fan Motor
* Troubleshooting
* 2-7 Fuel Injection System
* General
* Air Line
* Fuel Line
* Sensor and Switch
* Control System
* Self-diagnosis System
* Turbocharger System
* Component Parts
* Intake Manifold
* Air Intake Duct and Throttle Body
* Air Cleaner
* Turbocharger Unit
* Service Procedure
* Troubleshooting
* Supplemental Restraint System “Airbag”
* Precautions
* Pre-inspection
* Troubleshooting Chart for Self-diagnosis System
* Output Modes of Select Monitor
* Control Unit I/O Signal
* Troubleshooting for Engine Starting Failure
* Troubleshooting Chart with Trouble Code
* Troubleshooting Chart with Select Monitor
* General Troubleshooting Table
* 2-8 Fuel System
* Fuel Lines
* 6-1 Engine Electrical System
* Component Parts
* Starter
* Alternator
* Service Procedure
* Starter
* Alternator
* Spark Plug
* Ignition Coil
* Spark Plug Cord
* Troubleshooting
* Starter
* Alternator
* 6-2 Body Electrical System
* Engine Electrical (MPFI)
* Radiator Fan
* Lighting
* Cruise Control
* 6-3 Wiring Diagram and Troubleshooting
* General Description
* Working Precautions
* How to Use Wiring Diagram
* How to Use Super Multiple Junctions (S.M.J.)
* Wiring Diagram and Troubleshooting
* Power Supply Routing
* Charging
* Starting
* Engine Electrical
* Radiator Fan
* Lighting (Headlight)
* Lighting (Tail, Illumination, etc.)
* Room Light and Door Switch
* Stop Light
* Turn Signal and Hazard
* Trunk Room Light
* Back-up Light
* A/T Control
* A/T Shift Lock
* Electrical Unit Location
* Compressor Map – IHI BRL4016 (EJ22 Turbo)
Code: Select all
1992 Subaru Service Bulletins
* 2.2L 4-Cyl & 2.2L 4-Cyl Turbo – VIN (6)
* Removal & Installation
* Overhaul
* Engine Oiling
* Water Pump R & I
* Torque Specifications
* Engine Specifications
* Interference Verification Check for OHC Engine
* Specifications
* Capacities
* Quick-Service
* Mechanical Checks
* Ignition System
* Fuel System
* Theory/Operation
* Air Induction System
* Computerized Engine Controls
* Fuel System (Carbureted)
* Fuel System (Fuel Injected)
* Ignition Systems
* Emission Systems
* Self-Diagnostics
* Basic Testing
* Fuel System
* Ignition Checks
* Idle Speed & Ignition Timing
* Fuel Pump Circuit Tests
* Tests W/Codes
* Self-Diagnostic System
* Diagnostic Code Charts
* Read Memory Mode
* D-Check Mode
* Clear Memory Mode
* Crank Angle Sensor
* Starter Switch
* Cam Angle Sensor
* Fuel Injectors
* Coolant (Water) Temperature Sensor
* Knock Sensor
* Airflow Meter Circuit
* By-pass Air Control Valve
* Throttle Position Sensor
* Vehicle Speed Sensor No. 2
* Canister Purge Control (CPC) Solenoid Valve
* Air/Fuel Ratio Control System
* Idle Switch
* Wastegate Control Duty Solenoid Valve (Turbo)
* Pressure Sensor Duty Solenoid
* Atmospheric Pressure Sensor (Non-Turbo)
* Airflow Sensor
* Neutral Safety Switch (Man. Trans.)
* Inhibitor Switch (Auto. Trans.)
* Parking Brake Switch (Auto. Trans.)
* Tests W/O Codes
* Symptom Diagnosis (Carbureted – Justy)
* Justy Symptom Diagnostic Chart
* Loyale Symptom Diagnostic Chart
* Legacy Symptom Diagnostic Chart
* SVX Symptom Diagnostic Chart
* Intermittent Problem Diagnosis
* Wiring Diagrams
* Wiring Diagram (Legacy 2.2L PFI & Turbo)
* Component Location Menu
* Engine Compartment, Headlights (Grid 1-3)
* MPFI Control Unit (Non Turbo), Ignition Relay (Grid 4-7)
* Check Connector, Ignition Coil (Non Turbo) (Grid 8-11)
* MPFI Control Unit (Turbo) (Grid 12-15)
* Check Connector, Ignition Coil (Turbo) (Grid 16-19)
* Fuse Relay Box, Ignition Switch (Grid 20-23)
* A/T Control Unit, Shift Lock Control Unit (Grid 24-27)
* ABS Control Unit, Cruise Control Unit (Grid 28-31)
* Air Suspension Sensors, Height Control Unit (Grid 32-35)
* A/C Relay Box, Air Bag Control Unit (Grid 36-39)
* Front Wiper Motor, Hazard Sw (Grid 40-43)
* Instrument Cluster, Dome Light (Grid 44-47)
* Auto Shoulder Belt Control Unit, Pwr Windows (Grid 48-51)
* Power Mirror/Sunroof Sw, Tail Lights (Grid 52-55)
* Electrical Component Locator
* Buzzers, Relays, & Timers
* Circuit Protection Devices
* Control Units
* Motors
* Sending Units & Sensors
* Solenoids & Solenoid Valves
* Switches
* Miscellaneous
* Trouble Code 13 – Crank Angle Sensor
* Vacuum Diagrams
* Remove/Install/Overhaul – Turbocharger (Legacy)
* Effects of Incorrect Fuel Use: New Procedure
* Incorrect Oil Pump Cover Torque: New Specification
* Fuel Injector Replacement
* Incorrect Duty/ID/Data Charts: New Charts
* Updated Line Pressure Duty Diagram (1990 Legacy)
* Updated Line Pressure Duty Diagram (1991-92 Legacy)
* Updated Line Pressure Duty Diagram (1992 SVX)
* Updated Cartridge I.D. Chart for Select Monitor
* Updated A/T Data Ranges (1990 Legacy)
* Updated A/T Data Ranges (1991-92 Legacy)
* Low RVP Fuel Effects: New A/T ECU-ROM Installation
* Omitted Fuel Gauge Delay Amplifier: Not Used in USA
Posted: Sat Dec 06, 2003 7:54 am
by evolutionmovement
Awesome!! This is going to be so helpful with the kitchen motor to find all the parts I need to get and replace.
manuals
Posted: Fri Jan 02, 2004 2:51 pm
by bazhalliwell
i want to take the time to say thanks, i had my hard drive blow up 9 months ago and i lost all the info i had, even the book mark to this site i have just found it and now i have all this information to my legacy it is a good new year 4 me thnks
Posted: Sat Jan 03, 2004 12:46 am
welcome
Posted: Sat Jan 03, 2004 6:37 am
by JasonGrahn
yeah, i'm an ass. I didn't get you guys jack shit. I'm that jerky brother who simply says merry christmas.
Posted: Sat Jan 03, 2004 8:19 am
It's alright....you let me laugh at your brother getting drunk
Posted: Sat Jan 03, 2004 8:25 am
by JasonGrahn
Legacy777 wrote:It's alright....you let me laugh at your brother getting drunk
yeah, how often does one see a 15 year old beer bong guiness?
Posted: Sat Jan 03, 2004 8:26 am
hahahaha....no shit.
Subaru service manual
Posted: Sat May 22, 2004 12:20 pm
by donquijote
I have 1994 RHD Subaru Legacy L station wagon!
I checked out the service manual and it did not have the section that I was hoping to find. Would it be too much trouble for you if I ask you to scan a few pages in how to replace the transmission filter along with the detailed diagram of what each components are inside the transmission fluid pan? That would be greatly appreciated!
I have dropped the pan in an attempt to replace the transmission filter and the gasket. I removed all of the filter bolts inside, but it did not seem to have enough clearance to remove the filter due to a metal tubing right below the filter. If I know for sure what this metal tubing is for and if I can apply enough force to get the filter out, I will try to do it, but I hate to cause any damage to the metal tube.
My question is whether there is a peculiar way of extracting the transmission filter? If so, how is it to be done?
I really want to replace the filter, but if it is not meant to be replaced, I just might have to install a new gasket and put'em all back together!
Thanks for your time!
Posted: Sun May 23, 2004 5:21 am
The screen in the trans is really not a filter....it's just a screen. When i took mine out...you had to remove the crossbar....and just need to give it a little force.
If you want....you'd be better off replacing the add-on filter kit near the battery.
Part # for the kit is in the part # thread.
Posted: Sun May 23, 2004 12:49 pm
by donquijote
Thanks for the info!
Do most Japanese cars have this kind of crossbar nearby the filter, or is this something special to Subaru?
At any rate, since I wasn't sure of what this crossbar was for and I could not take the filter out, I decided not to mess it further and put'em all back to gether with a new gasket yesterday morning.
I will look into the add-on filter kit and it seems to be a much better option!
Thanks!
John
Posted: Sun May 23, 2004 4:32 pm
Not sure whether all japanese cars have this crossbar or not. It may be particular to the 4EAT tranny, which is used in other cars as well.
Posted: Sun Oct 24, 2004 6:01 am
I've added some more goodies.....check 'em out
Again Please right click and save as.
http://www.main.experiencetherave.com:8 ... nual_scans
1980_Subaru_Manuals
1990_Legacy_FSM_Supplement
1990_Legacy_Owner_Manual_Scans
1990-1994_Legacy_Parts_Manual_-_Engine
1992_FSM_(Engine_&_Electrical)
1992_Subaru_Service_Bulletins
1999_Legacy_FSM
2000+_Legacy_FSM
2002_WRX_FSM
2004_Impreza_WRX_STi_Factory_Service_Manual
Chiltons
FSM_Scans
Technicians_Reference_Booklets
Posted: Sun Oct 24, 2004 4:01 pm
You da man, Josh.
Posted: Sun Oct 24, 2004 5:28 pm
Had some issues with the pdf's not opening in an IE window. I've got everything fixed now.
Posted: Mon Oct 25, 2004 2:01 am
by THAWA
yummy
Posted: Sun Jan 02, 2005 9:04 am
by shockman
Hey Josh,
great site mate! Very cool with lots of interesting goodies!!
Just wondering if you have or can get a Service Manual for a 94 Model JDM GT Legacy Wagon, its a BG5A? I have looked absoulutly everwhere!
Posted: Sun Jan 02, 2005 9:33 pm
Sorry, but no I don't have any JDM manual stuff.
I would think most of the stuff would be similar to the US 95 legacies, minus the motor & some of the wiring.
You could maybe try to find someone in japan.
Thanks for the great stuff
Posted: Sat Mar 19, 2005 4:47 am
by TSiHawaii
I really appreciate all that you did. This is great stuff.
Posted: Thu Apr 21, 2005 6:43 pm
by snowjob
I almost Sh*t myself when I saw this
http://www.driftquebec.com/legacy/1992_legacy.pdf
It's for the Liberty crowd, but their is still a lot of useful Info Here., and I'm not sure if anyone here has pointed it out, but I'm voting this become a sticky.
I shall now be know as the king
Enjoy
Frazer
Posted: Thu Jul 06, 2006 9:41 pm
by jasinwa
Is it just me or is the site down? I am getting only failures on each link I try...even the root is dead.
Posted: Fri Jul 07, 2006 5:38 am
by entirelyturbo
The links work fine for me, but I think Josh has the root site locked so only he can see it.
