»  Announcements »  Stuff you need to know
#General Forum Rules
Custom Search
Login | Register
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
Author Message
 Post subject: General Forum Rules
PostPosted: Fri Jan 18, 2008 6:43 am
This has been requested by many members. It will grow and change, but it will always be the call of the Moderators and Administrators on any specific situation.
Discuss this topic by clicking here
Posting:
    All caps. Subject and body may not be all-caps.
    Images must be no wider than 800px. Moderators may remove links if they are wider.
    Links longer than 40 characters must use this format in order to avoid horizontal page scrolling:
    Code:
    [url=insert url here]insert description here[/url]
    Links to eBay sales (prime candidates for the previous rule) should be prefaced with "eBay".
Signatures:
    must NOT contain any colors, unless otherwise granted or specified.
    must have no blank lines, with a maximum of four vertical lines of text.
    must not have images present.
Discussions:
    When replying to a thread, be courteous. If you have seen the topic discussed before, please link to a relevant thread and/or insert helpful search terms for the original poster to use.
    Flaming will not be tolerated. Definition of "Flaming"
    Profanity is accepted, but should be limited to discussions where it is "relevant." If a part made you mad when it busted your knuckles, you've a right to curse. Don't curse at members.
Avatars:
    are not used on this forum by general membership
FAQs:
    The community needs to pitch in on this one.
Legacy Central
Profile  Offline
 Post subject: Re: General Forum Rules
PostPosted: Mon Jul 14, 2008 3:02 am
DLC wrote:
Posting:
Code:
I'm going to re-emphasize this rule! Please do not post eBay links as is!
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
