General Forum Rules
Posted: Fri Jan 18, 2008 6:43 am
This has been requested by many members. It will grow and change, but it will always be the call of the Moderators and Administrators on any specific situation.
Discuss this topic by clicking here
Posting:
Posting:
- All caps. Subject and body may not be all-caps.
Images must be no wider than 800px. Moderators may remove links if they are wider.
Links longer than 40 characters must use this format in order to avoid horizontal page scrolling:
Links to eBay sales (prime candidates for the previous rule) should be prefaced with "eBay".Code: Select all
[url=insert url here]insert description here[/url]
- must NOT contain any colors, unless otherwise granted or specified.
must have no blank lines, with a maximum of four vertical lines of text.
must not have images present.
- When replying to a thread, be courteous. If you have seen the topic discussed before, please link to a relevant thread and/or insert helpful search terms for the original poster to use.
Flaming will not be tolerated. Definition of "Flaming"
Profanity is accepted, but should be limited to discussions where it is "relevant." If a part made you mad when it busted your knuckles, you've a right to curse. Don't curse at members.
- are not used on this forum by general membership
- The community needs to pitch in on this one.
