Part number referrence needed
FAQs, community and board information.
ciper
Post by ciper » Thu Feb 27, 2003 12:04 am
We need a list of the common replacement parts. Stuff like knock sensors, oxygen sensors, thermostats, purge vavles etc...
Personally I need an oxygen sensor part for a 90 NA. Anyone help me out?
eastbaysubaru
Post by eastbaysubaru » Thu Feb 27, 2003 1:51 am
I'm pretty sure that the entire parts sheet is listed on Josh's website in PDF format. Josh, correct me if I'm wrong.
-Brian
Edit: Here it is:
http://www.surrealmirage.com/subaru/fil ... Sheets.pdf
'04 PSM FXT
Post by Legacy777 » Thu Feb 27, 2003 3:36 am
The parts list doesn't have engine stuff on it.
You guys are making me dig through my closet for parts boxes....you know that don't you.
I've verified the parts on subaruparts.com, that should mean they haven't been updated....but probably wouldn't hurt to ask the parts guy.
Coolant Temp sensor: 22630AA041
Updated Knock sensor: 22060AA031
MT, Diamond Coil Pack: 22433AA370
AT(black), MAF sensor: 22680AA160
AT, Idle air control valve: 22650AA034
Oxygen sensor: 22690AA150
Throttle Body gasket: 16175AA150
AT pan gasket: 31397AA040
ATF add-on filter kit: 31099AA091
Canister Purge Solenoid: 14774AA351
Ok....that's about it for my list right now....I may have some other stuff floating around, not sure.
Pretty much everything is for my 90 legacy n/a except the coil pack & possibly IAC valve....however they're pretty much the same as long as you go by reference on there about MT vs AT.
I had thought the atf filter kit # had been superceded....but it pulls up in subaruparts.com. Like I said....double check the numbers with the parts guy.
1997 Impreza OBS
eastbaysubaru
Post by eastbaysubaru » Thu Feb 27, 2003 6:20 am
Wow, thanks Josh. I can definitely use a few of those part numbers. You rock!
-Brian
'04 PSM FXT
DerFahrer
Post by DerFahrer » Thu Feb 27, 2003 5:16 pm
Josh's parts list doesn't have engine stuff or transmission stuff... mostly body...
I just hunted through it looking for shifter bushings, and I can't seem to find them :x ...
2000 Subaru Legacy B4 RSK
*Formerly subyluvr2212*
Please email me at fahrer4184@gmail.com if you want to contact me.
ciper
Post by ciper » Sat Mar 08, 2003 12:30 am
Oxygen (NA) 22690aa150 91.40
ball joint left 21067ga050 25.36
DerFahrer
Post by DerFahrer » Sat Mar 08, 2003 4:51 am
Timing belt 13028AA102 $63.43
Turbo/NA water pump 21111AA026/21111AA007, both $88.82
Thermostat 21200AA072 $14.03
Front crank seal 806733030 $8.83
Exhaust manifold gasket 44022AA020 $9.53
"16 VALVE" sticker 91531AA630 $30.80
PCV valve 11810AA000 $12.38
4WD nonturbo throw-out bearing 30502AA051 $34.95
4WD nonturbo throw-out bearing clip 30539AA000 $2.28
4WD nonturbo Clutch fork dust boot 30542AA000 $23.90
4WD nonturbo Clutch fork 30531AA110 $25.12
Bellhousing rubber cover 11413AA033 $5.38
90-91 nonturbo front bumper cover 57720AA010 $239.97
Nonturbo exhaust flange gasket 44022AA062 $7.98
Axle-back gasket 44022AA211 $8.63
Axle-back bolt 901660014 $1.19
Axle-back nut 902350001 $1.74
STi exhaust hanger ST440314S000 $9.95
Turbo rear swaybar bushings 20401FA021 $4.82
3-nipple PCV tree on block below PCV valve 11821AA221 $12.22
Parking brake shoe kit 26298AA020 $71.27
Wheelstud 28055AA002 $2.25
Axle nut 28044AA000 $4.37
Axle spring pin 051906452 $2.23
92-94 passenger side front fender 57110AA100 $169.95
92-94 turbo front bumper cover 57720AA120 $229.95
92-94 plastic bumper clips 57750AA090 $2.32
92-94 turbo LH fog light cover 57751AA120 $15.50
92-94 turbo RH fog light cover 57751AA130 $15.50
(note: these covers fit in the holes for the fog lights, they do not cover existing fog lights)
Front bumper chrome molding 57780AA010 $51.45
Tonneau cover supporting clip right side (left side similar) 65580AA000 $2.85 - you must add your interior color to the part number, e.g. BK for blue
Manual transmission drain plug gasket 803926070 $2.87
All prices are list price from http://www.subaruparts.com. Each individual dealer will vary in price.
Post by Legacy777 » Fri Apr 04, 2003 1:13 am
Just an FYI.......I picked up an entire 1990-1994 official subaru parts catalogue on ebay.
So I "can" find part #'s if you're in a bind, but I would prefer not to be the local subaru parts department ;)
1997 Impreza OBS
mikec
Post by mikec » Fri Apr 04, 2003 2:54 am
You shouldn't have mentioned it Josh, just mysteriously "known" what the part # was when no one could find it. :D
Post by vrg3 » Fri Apr 04, 2003 3:49 am
Hm, I'll take this opportunity to put up the contents of the "partnumbers" file in my home directory:
27011AA131 turbo rear LSD
114130151 brake line copper washer
25232AA020 ignition relay
16175AA150 throttle body gasket
22659AA060 IAC valve gasket
36015GA111 clutch pedal pad
623006021 acorn lug nut
28055AA002 lug bolt
22060AA031 knock sensor
22680AA170 aluminum housing hot-wire MAF
G3110AS100 90-91 Calsonic R-134a retrofit kit
G3110AS120 92-93 Calsonic R-134a retrofit kit
G3110AS000 90-91 Zexel R-134a retrofit kit
G3110AS010 92 Zexel R-134a retrofit kit
G3110AS020 93 Zexel R-134a retrofit kit
22690AA161 turbo oxygen sensor
22690AA150 non-turbo oxygen sensor
13028AA102 timing belt
26310AA092 turbo front brake rotor
26310AA112 turbo rear brake rotor
14035aa290 intake manifold gasket
22611AA694 turbo ECU
498307500 select monitor
498347502 90 select monitor cartridge
498348400 91 select monitor cartridge
498347601 90-91 select monitor cartridge
498348800 92 select monitor cartridge
498349200 93-94 select monitor cartridge
498347700 90-94 select monitor cartridge
11126AA000 oil drain plug crush washer
23700AA090 alternator
22012AA020 turbo pressure sensor
21200AA072 thermostat
11044AA282 turbo head gasket
11033AA114 non-turbo head gasket
I'm pretty sure these are all correct, and I've got others noted down in random other places on my hard drive, but there you are...
Edit: Fixed missing digit in LSD part number.
Austin
Post by Austin » Fri Apr 04, 2003 5:57 pm
http://www.subaruparts.com/diag/?model=4
If you follow that link, you can get part numbers for any legacy back to 1990. Not all the pictures are loaded, but you can select the system you're interested in, click on the part name, and it'll show you the part number in you shopping cart.
91 Turbo Legacy Sedan 5MT
02 Impreza WRX Sedan 5MT
02 Legacy Sedan 5MT
Post by vrg3 » Fri Apr 04, 2003 7:23 pm
That catalog has a lot of errors and is incomplete. There was apparently a project to make a web interface to all the parts CDs but it wasn't ever finished... The WRX catalog seems good and includes diagrams but the rest aren't really all that good.
DLC
Post by DLC » Sat Apr 12, 2003 10:23 pm
This deserves a sticky!
Legacy Central
Post by Legacy777 » Sun Apr 20, 2003 3:42 am
Thermostat Gasket 21236AA010
I know thermostat is already posted.....twice....but to here's both in one post
1997 Impreza OBS
ciper
Post by ciper » Wed Apr 23, 2003 2:20 am
Anyone have the part number for the Rear Right ABS sensor?
Post by Legacy777 » Wed Apr 23, 2003 4:06 am
Right Rear ABS Sensor 26740aa020 Which looks like has been superceded by 26740AA021
For posterities sake Left Rear ABS sensor is 26740AA031
1997 Impreza OBS
Nate S
Post by Nate S » Thu May 08, 2003 6:29 am
anyone have a part # for an atmospheric pressure sensor? ( for turbo )
thx
Nate
S-Squared
S-Squared Motorsports
Looking for aftermarket parts? Email me
nate@ss-ms.com - www.ss-ms.com
shop # 916 631 7440
92 turbo wagon / 02 wrx sedan
ciper
Post by ciper » Thu May 08, 2003 6:46 am
Thats the one on the right side strut tower with the solenoid valve right?
Nate S
Post by Nate S » Thu May 08, 2003 7:29 am
believe so
shop # 916 631 7440
Post by Legacy777 » Thu May 08, 2003 1:22 pm
If no one has it by this afternoon.....I'll get it when i get home.
1997 Impreza OBS
Nate S
Post by Nate S » Thu May 08, 2003 4:59 pm
cool, thanks josh.
none of my manuals here at the shop have it and I cant find it anywhere :shock:
Nate
shop # 916 631 7440
Post by Legacy777 » Fri May 09, 2003 3:56 am
Well.....I'm not positive I'm looking at the right thing....but I'm pretty sure.
But I think it's 14774AA340
The diagram has a cylindrical looking thing on it. The parts book gives it a name of Valve AY-SOL
1997 Impreza OBS
Post by vrg3 » Fri May 09, 2003 6:25 am
Josh - I believe that's the pressure exchange solenoid valve.
The pressure sensor, I think, is something like 22012AA020. I'm recalling that from memory, but I'm pretty sure that's it. That's a 2 bar absolute pressure sensor; the 1.5 bar one used on later N/A automatics is 22012AA070. I think.
I can verify this when I get a chance to look under my hood again.
Post by Legacy777 » Fri May 09, 2003 11:53 pm
Yeah...let me know.....I have the parts book....just not sure which piece it is.
1997 Impreza OBS
boostjunkie
Post by boostjunkie » Mon Nov 10, 2003 11:01 pm
The turbo MAP is in fact 22012AA020. I'm not sure about the n/a MAP.
