Part number referrence needed
FAQs, community and board information.
123c
Post by 123c »
Legacy777 wrote:It's called the abs ring. I could look it up when I get home. What year, model, etc car do you have?
1993 Legacy SS
Tone Wheel Front: 26750AA003
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
123c
Post by 123c »
New part number needed, I can't seem to find, even in that nice parts reference book Josh provided, and Subaruparts.com can be a little confusing at times.
I can't seem to find the number for the little rubber boots that go over the slide pins on the brake calipers, one of them has a small tear, so I figure I should replace it, and probally all of them...
1989 Honda Elite 50
[/color][/b]
You can't buy just the boot, however you can buy a rebuild kit that has the boots, seals and lube
Depending on when your car was made....there's two different #'s
If it was made on or before sept of 92 the # is
26297AA020
If it was made on or after oct of 92 the # is 26297AA021
123c
Post by 123c »
Do the rebuild kits also come with the anti-rattle clips?
1989 Honda Elite 50
[/color][/b]
no.....just the parts to rebuild the caliper
123c
Post by 123c »
Ok, here's another part I can't seem to find, I am looking for the bushings that go into the Stabilizer Link Assembly. I can't seem to find it, I can only find the Stabilizer Link Assembly, but no bushings for it.
1989 Honda Elite 50
[/color][/b]
eastbaysubaru
Post by eastbaysubaru »
I hope this is an easy one. I've got a few Grill Clips that are broken. The lower middle clip and the clip attached to the passenger side headlight are both broken. Does anyone have the part number for these clips? TIA.
-Brian
'04 PSM FXT
123c
Post by 123c »
outer clips: 91017AA010
inner clips: 91059FC090
1989 Honda Elite 50
[/color][/b]
eastbaysubaru
Which is which? I need one of the ones that attaches to the headlight (outer?) and one that attaches in the center on the bottom (inner?). Outer and Inner seem like they refer to the top clips as there are four of them. The ones that I need are the ones that the grill slides down onto.
-Brian
'04 PSM FXT
eastbaysubaru
Front wheel bearing:
28016aa011nt
Seals for associated bearings:
28015aa070 (inner?) not sure which is which
28015aa021 (outer?)
-Brian
'04 PSM FXT
The front wheel bearing should be part number 28016AA011. The inner seal is part number 28015AA021 and the outer seal is part number 28015AA070.
I think you need a snap ring for one or both seals; the snap ring is part number 28035AA010.
eastbaysubaru
Thanks for the extremely helpful reply Vikash. The part number for the wheel bearing has been superceded by the part number I listed:
28016AA011NT
-Brian
'04 PSM FXT
Cool.
I didn't see that you had edited your post. (That's what happened, right?)
An odd thing I noticed -- the GD-chassis WRX/RS has the same part numbers except for the inner seal which is part number 28015AA080. I would have expected it to be the same.
eastbaysubaru
Yeah, I edited it as I was calling the local Oakland dealership. They were actually pretty helpful this time and gave me all the associated part numbers that I needed. They didn't tell me about the snap rings though, so thanks!
-Brian
'04 PSM FXT
123c
Post by 123c »
As far as I know, there are no snap rings. I just had my bearing pressed last week, and the machine shop didn't say anything about one...
1989 Honda Elite 50
[/color][/b]
ferre
Post by ferre »
hi all :)
i'm wondering if anyone would know where i could get the part number for a JDM 2lt gt legacy auto ECU
or even better would be if anyone knows of a parts list for JDM legacy's
i noticed a similar question posted earlier in this thread but it was from awhile ago so i though i would ask in case there is any upadtes
Hmm....I don't have any JDM part #'s
There might be someone else.
Have you tried www.rslibertyclub.org/forums ?
THAWA
Post by THAWA »
Does anyone know the part number for the v8+/USDM STi, Legacy GT/Outback XT, Legacy 2.0GT oil pan. The twin scroll one?
is it different?
THAWA
Post by THAWA »
quite
how so? and what if any are the benefits....or is it just a fitment issue?
THAWA
Post by THAWA »
It is shaped to allow the use of twinscroll headers.
dzx
Post by dzx »
I remember hearing about twinscroll turbos but i dont remember what subaru's they come on. I do remember that there are quite a few differences in the setup.
///M
'93 Legacy SS - part out
THAWA
Post by THAWA »
They come on v8+ STi's and Legacy 2.0GT's :)
None that came in the USA correct?
