94 Legacy Wagon Turbo Partout.
midnight_turbo94
Post by midnight_turbo94 »
Hello I'm parting out my 94 turbo automatic wagon. I have the following parts still available:
EJ22T Long Block (120k miles) routinely serviced and in great condition. $500.00
EJ22T Intake Manifold w/ fuel lines and injectors $50.00
OEM IHI VF11 Turbo ( No shaft play, No leaks, no chips in the compressor wheel, always turbo timed and has only seen stock boost) $100.00
OEM Black Cloth Seats with dark gray inserts(front and rear) and a mint black dashboard.(sorry no cluster, or door panels) <-- Make me an offer for these.
Full Engine harness & EJ22T ECU, ( Missing two clips at most,will throw in dash harness as well) $120.00 (SOLD)
Have misc parts like the turbo heat shield and the turbo outlet pipe available too if you see anything you want then let me know:
I will also update with any parts I may have missed. Most of the parts like the engine block, dashboard, and seats are too large to ship and i would prefer local pickup. I'm located in the NY area.However if anyone wants to meet up I will drive as far as Jersey or maybe even PA with the parts. I can be reached at: 347-420-0727
Thanks for your time. :-D
Last edited by midnight_turbo94 on Wed Nov 24, 2010 3:04 am, edited 1 time in total.
midnight_turbo94
Re: 94 Legacy Wagon Turbo Partout.
bump, make me some offers.
93legacylsleeper
Post by 93legacylsleeper »
Do you have the Black turbo inlet pipe? The one that turns 90 degrees into the turbo?
kleinkid
Post by kleinkid »
The harness, ECU pic--Does that have the knock sensor connector, harness side? I'd be interested in that whole items pictured. Also the BCS, etc. and that fdn., hoses. Also, do you have a L or R rear Legacy SS caliper? Just need the piston, really.
bepa
Post by bepa »
good morning, am interested in parts. will call you later today if you don't mind. in new york city also.
be well, Bepa
91 SS/ 01 MB ML 55
Bronx, NY.
midnight_turbo94
93legacylsleeper wrote:Do you have the Black turbo inlet pipe? The one that turns 90 degrees into the turbo?
Sorry, I knew somebody would probably need that. my friend managed to break the ends off of it for the hoses when removing it.
midnight_turbo94
Still have the long block available, and price drop on the intake manifold. The seats are in great condition, pm me if anyone wants more pictures. I will take any reasonable offers.
Boost control solenoid (sold)
Engine harness and ECU (sold)
Coolant Reservoir (sold)
LIFiero
Post by LIFiero »
Have the cross member by any chance?
How much shipped to 11780 if available?
97 Impreza OBS
95 VW Passat GLX VR6 (going into Golf)
94 2.2L Legacy Wagon
92 EJ22T Legacy Sedan
92 VW Golf GL
89 VW Golf GL Wolfsburg
87 Mazda RX7 NA (traded)
87 2.8L V6 Fiero (sold to my brother)
66 Ford Mustang 289 Hi-Po V8 (for sale)
midnight_turbo94
^^ sorry I don't have the cross member.
James614
Post by James614 »
Just got my coolant reservoir in time for the weekend. Thanks :-D And thanks for the free extra pipe, I have no idea where it goes but I'll find a use for it ;-)
Edit: Just saw said pipe in pic above, now I know what it's for.
Turboturd
Post by Turboturd »
Can I get the intake resonator and the 90 degree elbow? I'm very interested.
Subiel94
Post by Subiel94 »
Turbo still available?
rolfimpreza widebody
Post by rolfimpreza widebody »
i want to buy your engine
let me know thanks
regards,
rolf
ej22tVermont
Post by ej22tVermont »
You have the ignitor or the Aux Purge valve left??
