For sale is a set of 890cc SR20 DeatschWerks Injectors in EJ25D rails with three Outfront Motorsports adapters. The FPR end of the right rail was tapped for 1/4 NPT as you can see. A factory FPR will not work anymore. I would not run this size of injectors with the factory series setup anyways. One can get hose ends to put them in on the cheap, or use AN everything. Options abound.
The adapters will work on any other rail of that style. I had them on the N/A EJ22E rails I used to have. Those rails are long gone, however.
The injectors have maybe 50 miles on them. I put them in the day before I got T-boned in the old car. They have not been used since. The blemishes were there when I bought them from DeatschWerks. I asked them if they could go bigger, and they said yes, but they used cosmetically blemished units since they have to ruin a few to come up with a matching set. Didn't bother me. The one that looks bad still clicks into the plug. I can dig up my harness and take off the plug bodies to send with as well. The pins are the same, so no splicing is needed if you are handy with a sewing needle. Also, you may notice I replaced all the pan head screws with 8mm hex bolts/screws on the caps.
$250 shipped
890cc SR20 DeatschWerks Injectors, rails w/ adapters
Re: 890cc SR20 DeatschWerks Injectors, rails w/ adapters
ok,
so are these side feed or top feed?
My modded WRX ones blow, and maybe these have more trim-ability than the regular wrx ones?
they are sidefeeds, as seen in pictures.
*sold*
*sold*
Bump for man-sized injectors.
Are they still available?
pm me, im interested....
thanks,
batlegacy
thanks,
batlegacy
PM sent.
