I know it's a long shot, but thought it'd be worth throwing out there...
Looking for a back left door for my '92 Touring Wagon.
Color Code 947 - MICA RUBY
Other doors will be considered since I will likely be doing a bit painting at some point.
Available for trade are parts from a '94 LS wagon (trim color - tan 440, exterior color - green 433 Spruce Pearl), including hood and front right door. I also have some Turbo parts available such as cross-member, radiator, temperamental wiring harness, well used front seats.
I'm located in Olympia / Seattle area, will road trip for the ideal door. No window or door card necessary.
I was mistakenly looking for a winestone door in an earlier thread, apparently I have an uncommon color for a'92 USDM Legacy.
WTB - Rear Driver Side Door - MICA RUBY - 947
1990 Subaru Legacy L Wagon - first subaru
1992 Subaru Legacy LE Touring Wagon - daily driver
1994 Subaru Legacy LS Wagon - parts car
Re: WTB - Rear Driver Side Door - MICA RUBY - 947
As far as I know, you can use any 90-94 door. That broadens your search a bit since Mica Ruby was available in 90-91 and far more common. You can use a sedan door as well as long as you put your wagon glass in it.
Ha, didn't even notice I replied to your other thread with basically the same info. Anyway, if you want to sell that crossmember for cold, hard cash, I'd definitely pick it up.
I've got a silver color rear driver side door from a 91 sedan that might work for you. It's in Portland, OR so not much of a drive.
https://goo.gl/photos/HwGqGWMPpcBVgdHQ9
https://goo.gl/photos/uUZ65HyScuBmCQCN8
Name your price.
Name your price.
1987 VW Westfalia Vanagon - EJ22T Powered
1994 Legacy Touring Wagon
Thanks again, Alphius.
You're first on the list for the crossmember if it doesn't get traded.
Maybe that will entice you to help me locate a Mica Ruby door
Thanks for the offer, Soobster.
I'm going to look for a Mica Ruby door for a bit longer, I'm checking out a potential match this weekend.
I'll keep you posted if I can't find one.
In reference to another thread of yours, I do trade parts for A/C work.
I picked up a matching door from a 1990 L wagon at the South Portland Pick 'n' Pull last weekend.
Unfortunately, the clear coat on the exterior is toast.
I'm already planning to repaint my hood for the same reason, so it fits my needs, but it'll probably be a while before I get around to it.
So, unless someone turns up with a match in better shape before I start painting, my search is complete.
