Performance and Stock Parts Garage Sale
Unfortunately fate saw it right to end my Legacy SS which has left me a with a pile of parts that are either spares or never made it onto the car. Everything must go.
I am planning to list the PFC, VF8, Injectors on NASOIC, but I wanted to give you guys a first shot at them. I'll put a tag next to them when I do it.
APEXi POWER FC for GC8A $600 Shipped Lower 48
[http://www.rs25.com/forums/f178/t227214 ... -gc8a.html]
[http://forums.nasioc.com/forums/showthr ... p=44612531]
Powers up but was unable to test beyond that due to it expecting COP ignition. Does not come with commander. Comes with a Field patch harness so you can switch to wasted spark with out having to cut your factory harness.
IHI VF8 TURBO w/ 90* inlet $250 Shipped Lower 48
[http://www.rs25.com/forums/f178/t227215 ... inlet.html]
[http://forums.nasioc.com/forums/showthr ... p=44612605]
Used, in great shape. When I purchased it I was told >40,000 miles. 1mm of side to side shaft play, no front to back shaft play.
Gray Injectors (440CCs?) on N/A rails $100 Shipped Lower 48
Pintle caps are falling apart, one is missing, second one is partially missing otherwise look to be in good shape.
AISIN Timing Belt Tensioner $100 Shipper Lower 48
New, still in original bag, never opened.
KOYO Timing Belt Rollers $Make Offer
New, never installed. One has some surface rust, the other doesn't. Both were stored in the same box indoors.
Goodridge GDA WRX Stainless Braided Clutch Line SOLD
BC Legacy Dome Light, Gray $15 Shipped Lower 48
Used, average shape. Lens has some scuffs, markings are somewhat worn.
Washer bottle with Pump $20 Shipped Lower 48
Used, average shape. Has scuffs and marks. Doesn't leak and pump works last time it was installed.
Rear Window Trim $Make Offer
Paint is messed up, rubber trim is missing or deteriorated. Top threaded attachment points are broken off. My plan was to glue them back in.
Misc trim hardware $Make Offer
New in package, send me a PM if you are interested
Legacy Pedal Covers $Make Offer
Used, Good Shape
Anything else pictured but not listed, send me a PM. If you want closer pictures of a particular item you are seriously interested in, send me a PM.
Used, Good Shape
Re: Performance and Stock Parts Garage Sale
Id like the stainless clutch line
Sent you a PMmike-tracy wrote:Id like the stainless clutch line
Posted up the Apex PFC to rs25 and NASIOC
Posted up VF8 to rs25 and NASIOC
Forgot to mention, I got the clutch line last week. Thanks for shipping it so fast!
You are welcome!mike-tracy wrote:Forgot to mention, I got the clutch line last week. Thanks for shipping it so fast!
wish i could afford the vf 8
Sent you a PMturbo970 wrote:wish i could afford the vf 8
Need this stuff gone, open to all reasonable offers.
Still need this stuff gone
