Aloha,OR - WTB: Robtune 550 Injectors
Posted: Thu Mar 02, 2017 11:32 pm
by camped69
If anyone has the true injectors for the 550 Robtune, please let me know.
They flow 525cc/min I believe.
per Rob, My “550” tune is uses the factory MY'04-06 STi/LegacyGT/ForesterXT yellow sidefeed injectors (actual flow is 525cc/min).
Thanks,
Chris
Re: Aloha,OR - WTB: Robtune 550 Injectors
Posted: Sun Mar 12, 2017 4:11 am
by impostor
Just fyi, make sure they have been tested before you install them, if you get used ones. I worked at the dealer when these were new and they had a very high failure rate. We kept them in stock we saw them fail so often. Now I'm independent and I'll still see a bad one every now and then. When I did my rob tune a year ago, I sent out two sets to be tested, and three of the eight were dead.
Jim
Posted: Sun Mar 12, 2017 5:06 am
by camped69
impostor wrote:Just fyi, make sure they have been tested before you install them, if you get used ones. I worked at the dealer when these were new and they had a very high failure rate. We kept them in stock we saw them fail so often. Now I'm independent and I'll still see a bad one every now and then. When I did my rob tune a year ago, I sent out two sets to be tested, and three of the eight were dead.
Jim
Thanks, will do. The last set of supposed 550s I bought were cleaned and flowed...tested as 440s, hence my new enquiry.
Sent from my LG-D851 using Tapatalk
Posted: Sun Mar 12, 2017 5:14 am
by impostor
Yeah, gotta watch for that. The 20k injectors were also yellow.
