Legacy Yard Sale with some performance parts HALF OFF
Posted: Sun Feb 10, 2019 1:00 am
I have a bunch of Subaru parts for sale mostly from a 94 BC turbo. I will be glad to calculate shipping for you. No low balls and no trades! Paypal F&F for all payments. I will not split up the parts in the groupings! All pictures can be found here http://s739.photobucket.com/user/waldo3 ... ar%20parts
Oil sandwich plate kit with AN fittings $5 - Used for turbo oil feed.
Stock Legacy turbo that is blown comes with all screws, oil drain, oil feed and coolant lines. $ 7.50
#9 stock oil pump $3
AC compressor with one AC line. It spins freely and worked fine when taken off the car. $7.50
Auto transmission flex plate $5
Two sets of outer timing belt covers for sohc. $7.50
Coolant gauge with sensor $20
Urethane bushing kit incomplete comes with 20mm front sway bar, 17 mm rear sway bar, RR trailing arm, half set of front control arm $25. Look at the picture some stuff is a half of a kit.
Oil pressure gauge with sensor $20
Dip Stick $3.50
Mechanical Boost Gauge with mounting cup $7
Stock ignition coil $2.50
WRX BOV $2.50
3 modified MAF sensors for blow through set up, assorted silicone couplers two - 3" to 2", two - 2" to 2" and one 90 degree 2" to 2" and six t-bolt clamps $30
Dip Stick $3.50
WRX BOV $2.50
