APS
Got a new part? Is it the best thing you've ever seen? Is it a complete ripoff? Let us know about your parts and service.
NICO
APS
Post by NICO »
wow i just got the full aps exhuste system apswrx-hoe-r1, A+++++
that down pipe cast iron piece is amazing, smooth, quiet, and made more mid and top end power like it says.
just amazing any one who is thinking of getting it get it.
http://www.airpowersystems.com.au/us_sp ... hoe-r1.htm
DLC
Post by DLC »
Cast Iron? Pfft, it's all about Inconel!
Legacy Central
NICO
Post by NICO »
yes cast iron, wow does it make a huge diffrence. smooth clean power with amazing top end, so happy i got it worth the money.
next is there intercooler for gc8 + there inlet pipe for the turbo, one under the intake manifold. i might even get the up pipe it cast iron as well.
93Leg-c
Post by 93Leg-c »
NICO, you had a 4 inch bellmouth DP before putting on the APS DP, correct? So, you can actually feel the improvement with the APS?
'94 TW
NICO
Post by NICO »
o man can you feel it, they make some nice stuff. mine was home made it worked, but aps uses thick thick pipes and a really well made cast dp. the spliter in the down pipe is sick way better then what i did.
