»  BC-BF Legacy Discussion »  Reviews
#Hallman Pro Manual Boost Controller
Custom Search
Login | Register
Post new topic Reply to topic  [ 16 posts ]
Author Message
 Post subject: Hallman Pro Manual Boost Controller
PostPosted: Fri Oct 10, 2008 9:19 pm
Well.. Ive barely had my boost controller on 24 hours and, oh! What a differance!
Installation is straight forward with easy to read instructions covering a variety of cars. (or even better, DLCs guide to installing a Hallman boost controller)
Performance gains noticed immediately, even at stock boost levels. With the stock boost controller (on my car) the turbo would kind of build up to max pressure over a second or so. With the Hallman it is RIGHT NOW. The car also seems to be making more power, even at stock boost levels.
Noise. Not only is the turbo louder, the noise is also higher pitched. A bonus for the sporty "look at me" crowd. I assume the turbo is spooling faster than with the stock controller thus the more noise, higher pitch and improved performance.
Installation Kit. Utter rubbish. Ok yes. this is a generic application Intended for use on a variety of vehicles. HOWEVER. The provided hose was to small, WAY to small. The "T" connector might have fit, if the hose was the right size. The vacume cap was, once again, to small. I ended up scrapping the whole lot and buying my own fittings caps and hose. Which, by the way, was cheaper than the amount spent on the installation kit.
In summery. Two thumbs WAY up for the Hallman Pro Manual Boost Controller. But don't waste your cash on the install kit.
Profile  Offline
 Post subject:
PostPosted: Sat Oct 11, 2008 1:55 am
Good to know. I appreciate the writeup, I'll probably look into this one once I get tuned.
Profile  Offline
 Post subject:
PostPosted: Sat Oct 11, 2008 2:05 am
I installed the Hallman pro on my car several months ago. I too would recommend it. Easy installation and noticeable increase on boost level reaching max right away.
'11 WRX Limited
'94 TW | R.I.P.
Profile  Offline
 Post subject:
PostPosted: Sun Oct 26, 2008 10:12 pm
I've had one sitting on my desk for months now, but haven't installed yet because I wasn't sure there'd be any gain staying at stock boost. I guess I'll have to go try it out now!
Profile  Offline
 Post subject:
PostPosted: Mon Nov 16, 2009 1:04 am
not to bring up a dead thread, but better than starting a new one. Is it necessary to have that little brass fitting ("breather hole") in the vaccuum system as shown in the install guide in the library? or would I be fine without it?
Profile  Offline
 Post subject: Re:
PostPosted: Tue May 01, 2012 6:37 am
Any pictures?
Profile  Offline
 Post subject: Re: Hallman Pro Manual Boost Controller
PostPosted: Mon Jun 04, 2012 6:28 am
I've had one sitting here for almost a year and have no idea how to install it haha never really looked but a picture would help thanks!!!
1993 legacy ss "Shela"
Profile  Offline
PostPosted: Mon Jun 04, 2012 9:50 am
Here's the link they referenced.
http://legacycentral.org/library/literature/hbc.htm
Profile  Offline
PostPosted: Tue Jun 05, 2012 2:49 am
Wow, So what's the difference in just having an MBC run off the nipple on the compressor housing verses the intake manifold???
Profile  Offline
PostPosted: Tue Jun 05, 2012 3:39 am
I say none. I've run it both ways, I could tell no difference in boost characteristics. I like running it off the compressor nipple because its less vacuum splices and a tad cleaner.
Profile  Offline
PostPosted: Tue Jun 05, 2012 5:47 am
Yeah, that's always how I've had mine set up to
Profile  Offline
PostPosted: Sat Jun 09, 2012 8:20 pm
Running it off the intake manifold can create greater chances for part throttle full boost.
1997 Impreza OBS
Profile  Offline
PostPosted: Sat Jun 09, 2012 8:27 pm
PTFB is a good thing, right? :wink:
Profile  Offline
PostPosted: Tue Jun 12, 2012 12:39 am
Good info. Im assuming from the wink that ptfb is no good. I'll me installing my hallman pro mbc sometime this week when i can make it to auto zone. Where should I spice in for the boost gauge? Is the intake manifold where suggested earlier a good location?
Profile  Offline
PostPosted: Tue Jun 12, 2012 12:57 am
Yes, the intake manifold is the only place you'll get both boost and vacuum readings.
Profile  Offline
PostPosted: Tue Jun 12, 2012 6:16 am
Thanks for the info!
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
