»  BC-BF Legacy Discussion »  Reviews
#Kartboy 1-Pot to 2-Pot adapter brakets
Custom Search
Login | Register
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Kartboy 1-Pot to 2-Pot adapter brakets
PostPosted: Sun Oct 06, 2013 5:33 am
THESE BRACKETS SUCK
ahem... My 4 hour brake upgrade turned into 12+ because of these things.
So what's the deal? You get the standard kartboy packaging. Lame sticker with l337 speak, cheap looking internal wrenching bolts and the brackets.
The brackets themselves look like nicely machined pieces. They are machined to tight tolerances. When you (finally) bolt them onto the car they are something to appreciate. Its a convoluted little space they are shaped to fill.
Enough with the sunshine. The problem I had is that these precision brackets with their tight tolerances are machined to higher tolerances than Subaru. Their bottom side profile that mates up with the spindle did not exactly match my car. This caused the bolt holes to be out of alignment. I tried grinding my upright but it became obvious I was going to have to remove too much material so I elongated the holes (really lame solution).
What further exacerbates this problem is that the brackets are made out of aluminium. And the two holes in question are threaded aluminium. Kartboy opted not to helicoil these threads, which means they are instantly destroyed by cross threading, and when holes don't line up guess what you are prone to.
-------------------------BOTTOM LINE---------------------------
For the price Kartboy asks, these should fit perfectly out of the box. For the amount these things are hyped as a bolt on solution I was disappointed on how much effort it took to make them fit. Buyer beware, these may or may not work for you.
Profile  Offline
 Post subject: Re: Kartboy 1-Pot to 2-Pot adapter brakets
PostPosted: Tue Oct 08, 2013 4:42 pm
I'm currently making brackets that will be a lot more affordable than the Kartboys and the install will be much easier as well.
Thanks for the review!
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
Profile  Offline
PostPosted: Tue Oct 08, 2013 7:10 pm
Yes, the custom fitment that everyone has to go thru....SUCKS!! If you drop 2 bills on brackets, they should fit like a glove.
I ended up grinding down the hub on my RS to fit the brackets.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
