»  BC-BF Legacy Discussion »  Reviews
#EBC Sport Rotors/Green Stuff pads
Custom Search
Login | Register
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: EBC Sport Rotors/Green Stuff pads
PostPosted: Tue Jul 15, 2014 3:30 am
Needed new rotors and pads and decided to try these out. Decided to try the drilled and slotted rotors. I know there has been some good conversations on these so I figured I'd try them out for myself. Haven't ever had a set before.
I use my car for delivery and wear out pads and rotors constantly. I have had them in for about two weeks. I did the break in that EBC recommended and then put them to the test. Spent a good three plus hours stopping and going from speeds of 10 mph on up to 60 mph and everything in-between. They felt solid and like they weren't working too hard whether it was a jarring stop or a smooth stop. Best combo I have used so far. I will check back in a month or two. Hopefully the next post is as good as this one!
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
Profile  Offline
 Post subject: Re: EBC Sport Rotors/Green Stuff pads
PostPosted: Wed Jul 16, 2014 3:52 pm
Are the pads you got the dp3966c?? I'm looking for a set of pads that will Truely work on the tleg and not for an n/a legacy.
2002 wrx sport wagon
Profile  Offline
PostPosted: Wed Jul 16, 2014 4:04 pm
Check out this link:
http://www.autoanything.com/brakes/61A3070A0A0.aspx
There is a model selection dropdown under "Front Pads". I selected the turbocharged option. They went in perfect!
Profile  Offline
PostPosted: Fri Oct 20, 2017 4:55 am
will check that out too
Profile  Offline
Who is online
Users browsing this forum: No registered users and 3 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
