Figured out the drivetrain problem
Registered for the event.
Made a hotel reservation.
Ready to face 3 hours of DC rush hour hell tonight
Rallycrosses in NC
Good times.
Arg! rallylegacy57 beat me by just a second in the NA Legacy! I need more practice
'00 Impr RS - sold
You forgot to mention I was on street tires to your rally tires. I will say the course probably favored the low end torque of the NA motor over the turbo motor. Either way it was great seeing another Legacy out again and and glad to see everything went well with your car this time Sam. Looking forward to coming up to Oakland Acres in July and running with you guys.rallysam wrote:Good times.
~Keith
1993 Legcy LSi AWD 5 Speed Rallycross car
Yeah, I was definitely thrown off by the course. Through those tight, slow, rutted turns with no traction, I bogged down at least once each run. No excuse, the car is capable of getting through that kind of stuff fast - I just need to learn how to drive through that kind of stuff!
'00 Impr RS - sold
