EJ22T beat a stock sti?
Autocross, Rallycross, ProRally, Drag, WRC, F1 etc...
tsbpenguin
Post by tsbpenguin »
Ok so my friend has a bone stock 06 sti. About 50,000 miles.
I want to pull on him from a roll and lower strip times would be nice as well.
I'm trying to keep it as cheap as possible up front.
This is the setup im thinking:
The car is a 93 Legacy SS
151,000 miles
STi 6 speed, diffs, axles, brakes, etc.
Exhaust
Intake
2.5DOHC Heads with SOHC Gasket
Matching Intake Manifold (ported maybe)
MBC (Set at ~13psi)
Big FMIC, or a TMIC
Will this get me anywhere close to him? Anything i'm leaving out?
legacy92ej22t
Post by legacy92ej22t »
With that setup? No. The STI will spank you.
You will 100% definitely need to upgrade the turbo if you want to take a STI. Now that you upgrade your turbo you will enter a new realm where you need to start thinking about fuel delivery though and more supporting mods. You'll need a Walbro 255 FP, injectors, EM so you can control timing and mix. You'll also need a FCD because you're going to need to run more then 13 psi even with a bigger snail....
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
mikec
Post by mikec »
I'm thinking you would also be better off finding a 4.11 or 4.44 5 speed, instead of using the heavy 6 speed.
tsbpenguin
Ok so with the 5 speed what 5 speeds can hold good power? Like a wrx 5 speed? If i'm to do that would i want a different gear set? Will it be as fast as the 6 speed?
In between Subies
biggreen96
Post by biggreen96 »
I'm making ~15 foot pounds less than a stock sti at the wheels according to cobbs dyno day/track day, my stock leggy 5 speed holds it. *Knocks on wood*
I subscribe to the "It's all in how you drive it" school of thought.
dscoobydoo
Post by dscoobydoo »
The WRX 5 Spd is a 3:56 or something close to that ( anyone feel free to correct me on the number)
One of the JDM transmissions that pop upon ebay from JHOT would be the way to go - and you can get the matching rear diff to go with it.
The 4:11 would be a good set as it would give you a quicker ratio but not limit the freeway speeds a 4:44 would
Check my earlier posts about my build.
I have a 16G, 565 injectors and a piggyback.
But I am still about 30 hp/tq from being even with a STI. But I have a few more things that I will end up doing to bridge that gap.
Search on other's builds. It will give you a good idea of what you will have to do.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Superman2.7t
Re: EJ22T beat a stock sti?
Post by Superman2.7t »
tsbpenguin wrote:Ok so my friend has a bone stock 06 sti. About 50,000 miles.
151,000 miles
Exhaust
Intake
MBC (Set at ~13psi)
Big FMIC, or a TMIC
The STi will destroy you. Hell, an STi will destroy everything but an Audi A6 2.7t.
BXSS
Post by BXSS »
My OBS-T used to run even-steven with my friend's '05 STi (intake+axleback) to my & his amazement. He eventually got tired of not being able to outrun my ghetto-turbo'd wagon & got turbo-backed / protuned. The first time he ever drove (any car) on a 1/4 mile track he ran 12.8....
Stock STi's are not that quick, but can get alot quicker easily.
I have not raced him with alky/more boost on the wagon, but I'm sure he will outrun me.
I think it is possible to outrun your bud with a stock EJ22T longblock with EM / big turbo (not a little 16G) & all nec accessories to make work.
A few guys I know say the 6spd is a handicap for the 1/4mile, but they are more serious than average folks.
O - my friend with the 05 STi has a family member with an Audi RS6 (twin turbo V8) that could not outrun an STi on the HW (mods on STi = unknown), but the RS6 guy is crazy & can drive.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
Superman2.7t
BXSS wrote: O - my friend with the 05 STi has a family member with an Audi RS6 (twin turbo V8) that could not outrun an STi on the HW (mods on STi = unknown), but the RS6 guy is crazy & can drive.
Hey Penguin,
What is your position on an RS6, the A6s big bad brother, being slower than an STi on the HW?
BXSS
Post by BXSS »
The question to ask is what was done to that STi.
One of my friends has a 589WHP (in '05 - ? HP now) '04STi, so to say an STi can't beat a 2.7TT A6 (which is heavier & slower than the old 2.7tt S4's that ran 14.1 1/4's stock) is silly.
The RS6 (13.1 1/4mile stock(R&T '04)) story goes like this-
RS6 guy told the STi's ower (a random STi that was next to him @ the time) that hid did not have enough HP to keep up as they entered the HW. I'm not sure what was done to the RS6, but it was not factory stock. When it could not walk the STi the RS6's owner was in shock. I forgot what the speeds went up to, as this happened a while back (when RS6's were new & still in production) but it was over 150MPH. He basically came back from the encounter with respect for the "stupid Subaru".
I wish I had a couple of this guys cars which include the RS6, Tech-art 996TT, M3 convertible & hardtop, M5........
Moral of the story = a well modded "slower" car, can romp a "faster" cars ass (our '82 Starlet that ran 0-60 in 15seconds stock runs 9.97sec. 135+mph 1/4miles now).
http://bbs.legacycentral.org/viewtopic.php?t=32633
Back to the original posters question I think it is possible to beat a stock(ish) STi with a modded LSS/ej22t.
Lets not kill this post with off-topic junk.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
farfrumwork
Post by farfrumwork »
Yeah, there are a lot of different ways to equal or best a Stock Sti with the turbo leg.
on top of the basics (TBE, intercooler, MBC) you WILL need a bigger turbo, more fuel, and more air metering capacity or MAP based tuning (the MAF goes to 200g/s, which might get you 220whp if you can control timing). Alky injection does wonders as well for low $$
And about the 2.7TT A6 - I have rolled those on the Hwy and can pull away from 65-90mph. I am *about* even with my friends S4 (2.7TT sedan) from a dig (he pulls a bit once over 80mph).... but a stock Sti will pull on me from any speed in any gear
The torque is fairly easy to get, it's the top end power that's tough - which means bye bye on the Hwy
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
justin the subie
Post by justin the subie »
my friend has a 06 stock sti.. weve raced a few times.. i would say were really really close to even.. ive beat him home, hes beat me home.. we were not or a track any of those times, a hwy with many turns so i would imagine he could win if we didnt have to slow down.. his car spools faster but he has never once left me behind..
>divorced wastgate 3" turbo back no cat
>04 wrx tmic/hks BOV
>tdo5 16g
>fcd 17psi
>whiteline springs/kyb agx struts
>04 wrx 16" wheels
>no a/c
>diamond coil
'92 TW "Hana" ej20tt obd1 <too many to list< sold :-( bought back :-)
drewriviera
Post by drewriviera »
I must say, it's all in the way you drive a lot of times. My 91 SS is a factory 5 speed and I kept up with an STI about a month ago stop light to stop light. I didn't really pull away, but then again I didn't really fall back either. You're not going to believe the mods that got my car to do this either....
NGK plugs and wires
Centerforce Dual Friction Clutch
KOYO Aluminum radiator
Fresh stock rebuild w/brand new factory fresh crankshaft (Very tight tolerances)
JVT stainless unequal length headers
ThermoTec Copper wrap on headers, integrated up-pipe and wrapped down pipe
Gutted cats
ThermoTec heat wrap shield over my stock VF-11 Turbo
Also, my brother took the turbo chimney and hood scoop pan off for better cooling by just opening the scoop up. Keep in mind that this was a very cold day, probably about 30 degrees outside.
douglas vincent
Post by douglas vincent »
Did he know you were there? :wink:
92ss satinsvoice
Post by 92ss satinsvoice »
douglas vincent wrote:Did he know you were there? :wink:
LOL
do a 100 shot of nos with supporting mods and you'll walk and sti at the 1320. something i would NEVER do because i hate nos but hey, it would work.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
drewriviera
Oh yeah, he knew I was there. But then again around here it may not even have been a real STI. People around Asheville are known for being the people that put "SS" emblems on any Chevy car, whether it be a base model Nova or Malibu. Also, they don't upgrade the engines to match :lol: Same goes for any "5.slow" Mustang in town also has to have the obligitory "Saleen" sticker on it.....garbage I tell you, garbage!
