Rally Car ideas
Rally Car ideas
I'm in the process of building a rally car and need some ideas, I am thinking of putting bigger tires on it and don't know if i need to lift it or not. All around i have some idea but i need the help of the Pro's here. Please give me some killer ideas if you gotem.
90 Legacy L wagon 5sM/T EJ22
It's hard being a grease monkey when you have two princesses at home.
check your local SCCA (www.scca.org) you're likely to have a rallycross group in your area.
FYI, National Rallycross has been held just outside Nashville, TN at the Super Speedway because we have the best course in the nation, and some serious space to play with (so says SCCA) so you should feel jealous, seeing as I get to drive that course sometimes
#82 M4 TRSCCA Rallycross
[/quote]FYI, National Rallycross has been held just outside Nashville, TN at the Super Speedway because we have the best course in the nation, and some serious space to play with (so says SCCA) so you should feel jealous, seeing as I get to drive that course sometimes
Yeah but you dont get too see them racing down a 2 track at 60mph with 2foot of snow !
Try the "Sno-Drift" in Alanta Mi. in the middle of January!
now that looks FUN!!!!
Word to the wise...When you are a novice rally driver, Rally America requires you to drive a 2wd car for your first 11 coefficients or so.
I don't know if you were planning to get into stage rally, but if so, that is an important point to consider.
