»  BC-BF Legacy Discussion »  Motorsports
#Teaser pic of the rally car.(Biggreen's rally build)
Custom Search
Login | Register
Post new topic Reply to topic  [ 119 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: Teaser pic of the rally car.
PostPosted: Fri Jul 23, 2010 9:56 am
That's a crazy cheap price. I thought those things were up in a the 3K range.
Profile  Offline
PostPosted: Fri Jul 23, 2010 10:14 am
They are. I still can't believe it.
Profile  Offline
PostPosted: Fri Jul 23, 2010 2:33 pm
Where did you get the gussets, or did you make em? What did you do w/ the fuel lines where the front of the A-pillar tube mounts?
93 legacy wagon L, 22T swapped (TW imitator) now with five forward speeds.
johndrivesabox wrote:
Rally, my kyboard is brok, his has nohing o do wih h liquor.
Originalcyn wrote:
Apparently everyone hates Gabe.
Profile  Offline
PostPosted: Fri Jul 23, 2010 4:34 pm
Made em' its thin sheet metal, bent around the tube by hand in a vise. Fuel lines are moved inboard slightly. I might redo them, if they turn out to be in the way of my feet.
Profile  Offline
PostPosted: Mon Jul 26, 2010 6:42 am
6 sppeeeedddddssss baby!
Profile  Offline
PostPosted: Thu Jul 29, 2010 7:22 am
Hacked the dash up to fit into and around the cage. Poor dash...
Mounted the 6mt shifter and am trying to find a good spot for the hydro handbrake. I think I need to hang the trans and connect the shifter so I can tell exactly where the gears will be so I can get the handbrake placement perfect.
Still need to paint, but first the handfull or random brackets need to be welded in...
Now that I have the 6mt I have 2 5mt's and a rear diff for sale
nastyclock link: http://forums.nasioc.com/forums/showthread.php?p=31423924#post31423924
Profile  Offline
PostPosted: Fri Jul 30, 2010 4:05 am
Nice score on the 6mt. I would put Extra-S in it to alleviate possible grinding.
What are you going to do about knuckles and brakes?
Profile  Offline
PostPosted: Fri Jul 30, 2010 5:14 am
You should leave the turning-brake lever where it is in the pic and fab up an offset/taller gear lever.
Profile  Offline
PostPosted: Fri Jul 30, 2010 6:47 am
THAT is a great idea actually. Having the shift lever closer to the wheel would really be beneficial too.
Knuckles and brakes... are staying stock. Gotta have 15in wheels for the rally tires. I really really want to use the r180 but I can't justify spending 600 dollars for spec-b axles.
Profile  Offline
PostPosted: Fri Jul 30, 2010 7:15 am
The Spec-B axles don't really work due to their length.
Hybrids are also not possible. I learned the hard way. Run an R160 with a good diff and you'll be fine. (Cusco RS, cough). Otherwise, you need Brembos, Subaru 2 pots, or redrilled SVX stuff. A good friend runs SVX stuff to use 15" wheels....
Profile  Offline
PostPosted: Fri Jul 30, 2010 2:35 pm
Every once in a while a good one falls out.
WRX two-pots fit under Team Dynamics wheels.
Profile  Offline
PostPosted: Sat Jul 31, 2010 6:54 am
Glad to see you're making progress, I'm still jealous about that tranny. ;) Good luck and hope to meet you in person some day.
Profile  Offline
PostPosted: Sat Jul 31, 2010 7:40 am
Thanks Mike, tonight I hung that 6mt. !!! it's heavy, 5mt I could do myself. Not this beast. Got the shifter attached and decided on a place for the handbrake. Just made the little bracket and now I'm about to weld it on. I'll drive it out to Seattle one of these days...
Profile  Offline
PostPosted: Mon Aug 02, 2010 8:19 am
Did a little more work today. Hot garages are no fun to work in. Motivation is LOW when temps get high.
Hacked the upper dash to fit the cage, finalized the hydro hand brake location, decided where to mount the battery, got discouraged looking at the wiring mess.
I decided to bail on the Sti struts. There is no way they will hold up to rally. AGX's are a joke. I have blown the shit out of the set on my Touring wagon. I'm going to get JVL's bilsteins.
Profile  Offline
PostPosted: Mon Aug 02, 2010 8:39 am
I have these struts on my Legacy and they are amazing on a gravel road. Also John is great to deal with, highly recommended.
Profile  Offline
PostPosted: Mon Aug 02, 2010 8:44 am
He asked me to determine what my car weighs, but I have no idea. Is yours caged? What is it's weight?
Profile  Offline
PostPosted: Mon Aug 02, 2010 3:42 pm
Your cage looks awesome. I might be building a rally cage later this season, we'll see.
I gotta say though - Your shoulder harness mounts are pretty scary, the mounts are waaaaaay too far down . Other than that, everything looks really good! Great score on the 6MT too!
http://www.slodriveracing.com
-And more!
Profile  Offline
PostPosted: Mon Aug 02, 2010 4:35 pm
??? They are at equal height with my shoulders...
Profile  Offline
PostPosted: Mon Aug 02, 2010 4:47 pm
They are & they aren't. Although they wrap around a bar that's at shoulder height, the fact that they're actually mounted near the floor leaves a lot of dangerous slack, and allows for more belt stretch than you would want in a wreck. If you can mount the shoulder belts directly to the "harness bar", you'll be tons safer. :)
-And more!
Profile  Offline
PostPosted: Mon Aug 02, 2010 6:12 pm
Ok gotcha. That was sort of the aim, to have the stretch. But I definitely don't want to nail the steering wheel.
Profile  Offline
PostPosted: Mon Aug 02, 2010 6:30 pm
biggreen96 wrote:
Ok gotcha. That was sort of the aim, to have the stretch. But I definitely don't want to die.
Fixed it for you. :lol:
-And more!
Profile  Offline
PostPosted: Wed Aug 04, 2010 4:47 am
Looks good Biggreen!
And mr slodrive, I promise to call you when I get a second...
2011 Mini Countryman S All4
1970 Honda Ct90
Profile  Offline
PostPosted: Sat Aug 07, 2010 10:13 pm
Hey sorry it took so long. I don't have the actual weight but I would guess between 3150-3300lbs. I think he needs to know for the dampening and rebound specs, I can give you the ones off of my struts if you want. Then he can just match it with the spring rates
Profile  Offline
PostPosted: Sun Aug 08, 2010 2:41 am
Do you have any videos of the car sliding around or jumping with the jvab stuff?
Profile  Offline
PostPosted: Sun Aug 08, 2010 6:52 am
^^^No, only photos right now.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
