possible ej22t swap...
Locked
Jack
Post by Jack »
...into a 95 L. What would be needed to do the swap assuming im
starting with a doner 91 Sport Sedan minus trans and a 95 Legacy L 5
spd?
p.s. the 95 IS awd.
milehial2000
Post by milehial2000 »
It can be done and it really isn't to much of a project. I have a
EJ22t in my '95 Impreza. You have to swap the crossmember so that the
exhaust manifold will clear and then bolt the engine in. I am going
to run the EJ22t in my Impreza with a '98 ECU and a boost controller
and the same could be done with the '95 ECU. I manufacture a chip
that is on the market and it is being upgraded to control the timing
and hold it back to 35 degrees max advance and I plan on running 15
lbs boost with the new ECU and my intercooler. If you need any help
or have sny questions just ask.
AL(CO)
Locked
