Hey Yoya,
I like it. Please hook me up with a set of spacers
Although, for the top mount cooler crowd, I think it's already a squeeze
between the firewall and the throttle body.
One possible slick trick learned on a manifold I got from from Paul Eklund is
to shave the manifold surface that mates to the throttle body for a little
extra TB to firewall clearance.
That head port interchange question is a good one. I think it will need a
direct visual comparison because different port spacing can result in
different part numbers, but the shape can be identical, permitting phenolic
interchangeability.
Pleas let me know if you received this message.
Larry Witherspoon
Phenolic gasket/spacer YES
Thanks!
BTW everyone, If I didnt make it clear before the guy Im buying them from is
the Author of that article....
