well guys, I took apart the gear box cause of some noise in all gears, andI found the main gear on the input shaft to be missing some teeth... guess I have to replace that main shaft, bearings and what not...
ugh, well atleast this car will be 100% when done. yeah i got the leaking subroof too. anyone know if the trannie from the legacy twin turbo will bolt up? I can get one for cheap dn im just leery about if it is a bolt up or not. I know most are swappable.
mike
91 legacy turbo sedan, with too much mods to list.
gear box
