»  Archive »  BC-BF Legacyworks Archive
#Piston slap engine vibration at idle survey; reply to:
Custom Search
Login | Register
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
Author Message
 Post subject: Piston slap engine vibration at idle survey; reply to:
PostPosted: Mon Mar 03, 2003 11:46 pm
Sorry for the interruption BC-BF owners,
Robert Faulkner (Subaru2 group)and 2.5L 2000 and newer owners,
I read several weeks ago about R. Faulkners problems with his car:
poor paint upon delivery and also what sounds like ( valve chatter)
engine piston slap.
My 2003 Baja got piston slap after 2000miles of use, I also have a
noticeable engine vibration at idle after proper warmup. Vibrations
much worse at the passenger side of engine. Engine seems out of
balance. I sense vibrations by pressing on the front ignition wire
rubber boot on the side of head. Factory Rep, Ed Luksic, says my car
is normal. I don't believe a word he says. Has anyone in this group
tested or own 2000 and newer 2.5L Subarus?
Could you describe your piston slap?
Can you sense engine vibrations as I have described?
Who else has piston slap out there?
Engine vibrations at idle?
Robert Illan
1993 Legacy 5spd 133kmi runs great. Wish my Baja was as good.
illanrob@juno.com
PostPosted: Thu Mar 06, 2003 4:19 pm
You may want to check out the ultimate subaru message board for more info. There's been some recent posts about it. http://pub1.ezboard.com/bultimatesubarumessageboards
PostPosted: Fri Mar 07, 2003 10:49 am
I have a 2001 Legacy GT, 30k miles on it, It has piston slap.
Matt
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
