»  Archive »  BC-BF Legacyworks Archive
#diff issues!!!!
Custom Search
Login | Register
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
Author Message
 Post subject: diff issues!!!!
PostPosted: Fri Mar 07, 2003 1:29 pm
well guys, here I am holdin my #@$% in my hand and staring at two differentials. one of them is my 3:90 LSD setup and the other is a 4:11 open from mr richard buckner. Unfortunatley they are TOTALLY differnt pieces and none of the parts are interchangable. so here I am with two diffs totally taken apart. heres my ideas, and i need your opinions on it.
-take the 4:11 ring and pinion out of the open set, and "modify them to work in the new unit, down side, no guarentees they will fit and we might end up with two non-resellabel units.
-pay $500 for a 4:11 rear diff (in case, complete) at the local subaru only yard.
-put my 3:90 diff back together and open up the legacy TT trannie and put the 3:90 pinion and ring gear out of my old case on it.
-get a ring and pinion set out of a legacy GT, or forester S with a 4:11 rear set. questions, are all the subaru LSDs the same units? is my 1991 LSD the same LSD used in the GT and S model, if so then the ring would bolt up.
these cases are different and Im not sure the pinion shafts would be interchangable.
please smatter me with ideas.
mike
PostPosted: Sat Mar 08, 2003 2:59 pm
Mike I think all the diff gearings have to match
front center and rear
most of all don't pay 5 large till you check some more
here's a couple of my fave salvage sites
car parts . com
http://car-part.com/
hal's parts and service
http://www.halspartsandservice.com/
s-t-a-r auto recycling
http://www.s-t-a-r-usedparts.com/
planet salvage
http://www.planetsalvage.com/cocoon/ps. ... ion=rlogin
let me know if you find anything
Larry Witherspoon
ssspoon@aol.com
Who is online
Users browsing this forum: No registered users and 5 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
