KEEP BLOWING THE SAME FUSE!!!! HELP
Hey all I am blowing the same fuse now its the third time that it has happend. It is the sbf no2 I have put 2 30A in both have blown next I put a 40A and reset the ecu 2 times and it blew again. So I think I have a short some were just curious what sbf no2 controlled to look for the short.
One of the crazy's boosting a NA!
14.3 @ 93mph
14.3 @ 93mph
That will definately do it, and don't ever put any fuse rated higher than what is supposed to be in there, especially in the main fuse box. A fire isn't too far out of the question in a situation like that.
Yah I have new harnis in the mail and I was talking to my electrical engenier friend who said putting in a bigger fuse does nothing but cause an electrical fire do to the wire not being able to take it, and that no matter what fuse I put in the same amount of power is sent to the coil.
14.3 @ 93mph
14.3 @ 93mph
Well in the case where a fuse is blowing, more power is being sent to the destination, than intended. So you could theoretically find a fuse of the right size that would allow all power to go through the wire. Of course if the wire isn't rated for it, it will heat up and eventually catch fire. So again, listen to your friend and don't put a higher rated fuse someplace that doesn't call for it.
